acceptable oil useage
Postby Wolfie » Fri Oct 14, 2005 1:05 pm
what would you call acceptable oil useage??? on a 1972 mk1 47000miles of the clock.
Using about 0.5l every 500 miles at the moment is that about right or not???
Wolfie
Postby madmark » Fri Oct 14, 2005 2:53 pm
that is unusal but is there any sighns of blue smoke from the exhaust! :?
Postby Neil » Fri Oct 14, 2005 9:48 pm
we had a 95 2.5 di swb van 400 miles a week mainly flat out motorway and used 15 ltrs a week never broke down
Neil v6
Neil
Postby MrMPuk » Sat Oct 15, 2005 12:03 am
Must have cost you more in oil than fuel!
Postby Wolfie » Sat Oct 15, 2005 12:01 pm
madmark wrote:that is unusal but is there any sighns of blue smoke from the exhaust! :?
only well cold, every now and then get a puff when i change gear
Wolfie
Postby Luke » Sat Oct 15, 2005 12:12 pm
My Di uses quite a bit of oil, but i know where its going!!! all over the drive!! :lol:
Wolfie got any piccs of your mk1 :?:
Postby madmark » Sat Oct 15, 2005 1:06 pm
:shock: i would say she is useing a little ,but that would be ok ,as long as its not pooring out blue smoke! dont forget to run it on 20/50 nice and thick this might help as well! :D
oil
Postby pete_the_4x4 » Sun Oct 16, 2005 11:33 pm
i had a maxi once it used 5l of oil from ilford to ipswitch bit of cream it was
if you think my van is dirty you should see my pants
pete_the_4x4
Postby stooy » Wed Oct 26, 2005 10:33 am
I do about 250kms per week in my Mk1 and i use aproxamlty a 1litre ever two or three weeks, i know my motor is a tad tired and it has worn valve guides - common in aussie falcon 6 cylinders. I blow a puff of blue on start up once its warm and apart from that no visable smoke or problems.
stooy
Postby Wolfie » Thu Nov 10, 2005 2:02 pm
nope not yet luke will try and sort some for you.
Wolfie
Return to Mk 1 & 2
