Towing with a T430/460 140
Postby anrw » Sat Dec 06, 2014 8:54 pm
I am weighing up the options for replacing my Sprinter. I need to upgrade to a heavier vehicle and I am comparing the Iveco 50C15 (or 50C17) with a Transit T430 or T460 140. This is for a rally 'barge' and will run close to the max GVM of the van and tow a trailer / rally car combination that weighs 2300kg.
Anyone got any experience in towing this sort of weight with a transit? The venues we go to are often in hilly or mountainous areas so it would need to be reasonably performant towing this load up gradients!
Also can anyone point me in the direction of some specs for the Mk6/Mk7 T430 & T460? I'm struggling to find the useful stuff - MAM or GVW and GTW or GCW!
anrw
Re: Towing with a T430/460 140
Postby Altransit » Sat Dec 06, 2014 9:08 pm
You'll need to check the plated weights of whichever vehicle you choose, as they can vary according to the exact specification, but so far as I'm aware, the GVW of a 430 is 4300kg, (unless it's been downplated) and the GTW should be 6500kg :|
Postby karl » Sat Dec 06, 2014 9:09 pm
didnt think they done a t430 in a transit if they did you would need a taco as well :)
but then again a could be corrected :D
karl
Tranny Lover!!!
Postby blue estate » Sat Dec 06, 2014 9:12 pm
karl mcghee wrote:didnt think they done a t430 in a transit if they did you would need a taco as well :)
It will have one but opp does not have to use it if for own use but does need a cat C1 (7.5t ) on licence :wink:
blue estate
Postby karl » Sat Dec 06, 2014 9:18 pm
but then this is mine
Primary Features
Build Date: 26.04.2001
Vehicle Line: Transit 2000-2006
Cab Style: Regular Cargo Van
Series: 1.7-350L Series
Engine: Duratorq DI 2.4 (90PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.13
Emission: Light Duty Truck Stage III
Territory: (+)"GB"
Paint: Diamond White 73
Interior Colour: Dark Graphite
Interior Fabric: Stylize (-I-C)
With High Roof
Less Roof Line Conversion
With Rear Mudflaps
With Front Mudflaps
With Full Partition - Steel
LH Sliding Side Cargo Door - High
With Hinged Rear Loading Doors
With 270° Cargo Door Check Arms
With Standard Liftgate
With Aux I/P Console - 2 Din Horznt
With Standard GVM Rating
Increased 4250KG GVM Rating
Genk Plant Build
Less SVO Application/Label
Marketing Level 3
With Fixed Rear Window
karl
Tranny Lover!!!
Postby philytl » Sat Dec 06, 2014 9:21 pm
hello
iveco 50c15 has a train weight of 8.7 ton, transit 430 has train weight of 5.5 ton, but bare in mind you will need an operators licence if using any van over 3.5 ton, this will need 8-12 weekly checks
phil
philytl
Postby blue estate » Sat Dec 06, 2014 9:23 pm
philytl wrote:hello
phil
only for Hire reward or haulage not for personal use and the tax is lower £165 ish
blue estate
Postby karl » Sat Dec 06, 2014 9:23 pm
philytl wrote:hello
phil
6 weekly checks they are for commerail operators
karl
Tranny Lover!!!
Postby philytl » Sat Dec 06, 2014 9:31 pm
karl mcghee wrote:
philytl wrote:hello
phil
i was just assuming the op would be using a van for work as i do, therefor it would be for business use, also if he is taking a rally cor for compatitions then i would imagine there is prizes if you winn, then it is being used for reward
phil
philytl
Postby paul2012 » Sat Dec 06, 2014 9:41 pm
Any vehicle that has a GVW of over 3500lg (3.5t) requires a C1 licence to drive it & then you can only tow up to 750kg max.
To tow anything heavier then you will require C1+E licence.
Tacho will be required if used for business use - Commercial/Hire reward
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Guy88 » Sat Dec 06, 2014 10:37 pm
paul2012 wrote:Any vehicle that has a GVW of over 3500lg (3.5t) requires a C1 licence to drive it & then you can only tow up to 750kg max.
if you have C1+E on grandfather rights you have a restriction code,
class 1 licence needed :(
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Guy88 » Sat Dec 06, 2014 10:40 pm
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby karl » Sat Dec 06, 2014 10:43 pm
true as they guy a do alot of work for can only drive upto a 8 wheeler on his luckly me brother has a full class 1 so sometime i have him to pick machines up for us :lol:
karl
Tranny Lover!!!
Postby karl » Sat Dec 06, 2014 10:47 pm
i think them big vans look better with twin wheels 8) a think mine would look better with twin but she 14 year old and does what i need hear to do :D get me wheree i need to be without blowen pistons or blowen prv :!: :lol:
karl
Tranny Lover!!!
Postby V184 » Sat Dec 06, 2014 11:02 pm
WTF is commerail operators ?
Get a 4.5/5 ton Sprinter !
V184
