I bought the bulkhead about 2 and a half years ago , its solid wood and has been covered with some material (before I bought it)
it appears to have holes drilled so you can secure it to your TC pillars (behind the cabin doors) but I cant be sure as I never properly fitted it, I only ever secured it using a couple of cable ties.
There is a hole drilled in the middle lower edge (just behind the handbrake console area) that I believe was used by the previous owner to heat the rear section of the van with some sort of heater. it is pretty solid, and has the added benefit of having a sliding "hatch"
I want to add that the material on the corners has started to come away from the wood, but should be easy enough to sort with a bit of super glue
Only getting rid of it as I bought an Original Ford Metal Bulkhead last summer, and now I need the space in the garage.
ideally you would need to collect it as its too big for a courier to handle (especially as its a single piece and doesn't break down), however if you are local-ish to the Motherwell/Glasgow area I may be able to deliver it for a small "donation".
Serious enquiries only
