Help, gutless van
Help, gutless van
Postby clueless » Thu Mar 29, 2007 6:59 pm
Hi guys, complete newbie here.
I've got a 125td transit 02 Motorhome, its been all over europe in the last few years without a hitch cruising comfortably at 120kph/70mph, now it just wont go above 100k or 60mph it feels like its lacking power through the gears and is making a gurgly noise, (although the misses says she cant hear anydifferent) You wouldnt believe what that 10mph loss means, i was being overtaken by all the lorrys, and have no guts to pull around any in front? Theres no smoke or any difference in idle etc, just doesnt seem to have the guts.
Please help, I've just picked it up from the garage who said theres nothing wrong with it and it pulls fine, Still couldnt get it above 100kph with my foot flat to the floor, It had an interim service but i checked the oil before I drove away and it was BLACK, i went and asked if it had been flushed and was told yes, they drove the van for about 5k after the service to try and find the fault i described, would the oil discolour that quick? or are they pulling a drain and refill job on me?
clueless
Postby BigNeil » Thu Mar 29, 2007 7:46 pm
has your accerlerator cable stretched ?
BigNeil
Postby MrMPuk » Thu Mar 29, 2007 7:47 pm
BigNeil wrote:has your accerlerator cable stretched ?
Doubt it as it's electronic.
Postby Azer van man » Thu Mar 29, 2007 10:00 pm
You could try some injector cleaner
Azer van man
Postby AndyG » Thu Mar 29, 2007 11:26 pm
A 125 should pull well :!: :o :o :o
Drive it until your current diesel runs out (not completely :lol: )and put some BP Ultimate in it and see :idea:
I presume the filters, air and fuel, have been changed :?:
Postby clueless » Thu Mar 29, 2007 11:43 pm
yeh it did pull well, we use it for jet ski racing around europe and even towing a trailor it comfortably pulls to 75mph,
Not sure about the filters as im not even convinced the oil has been changed? Shouldnt be black and thin 5miles after flushing and changing should it??
clueless
Postby gemini » Thu Mar 29, 2007 11:48 pm
clueless wrote:yeh it did pull well, we use it for jet ski racing around europe and even towing a trailor it comfortably pulls to 75mph,
will be black as soon as you have started it :wink:
gemini
Postby BigNeil » Thu Mar 29, 2007 11:50 pm
what did the garage charge you for?
I always ask to see the old filters etc. from the garage (as i have marked them ) and then know what has been done. ( i am that trusting sort :wink: )
BigNeil
Postby clueless » Fri Mar 30, 2007 1:50 pm
Just been told the inlet manifold has split???? A two piece plastic part, costing £175 plus VAT is this for real. Help
clueless
Postby AndyG » Fri Mar 30, 2007 5:33 pm
clueless wrote:Just been told the inlet manifold has split???? A two piece plastic part, costing £175 plus VAT is this for real. Help
:( I'm afraid so :( :( It's a MK6 :(
Still, it has to be done :!: And it will restore the power :D 8) :wink:
Postby gemini » Fri Mar 30, 2007 5:53 pm
crappy plastic
gemini
Postby belly » Fri Mar 30, 2007 6:11 pm
could it be plastic welded?
belly
Kaiser Chief
split plastic manifold..
Postby transit4ever » Tue Apr 03, 2007 10:15 am
I have the same problem on mine, its had this problem since before Christmas, took it to 3 garrages who couldnt find whats wrong, 2 thought it could be the turbo pipes split but werent sure.
After enduring the lack of power for so long I eventually gave up yesterday and took a look myself, and it clearly was hisssing from the inlet manifold............
Is it easy to change?
I have sourced a second hand one for £47 delivered from Alm Kyme breakers.
Faz - transit4ever as they really do last.
http://www.oxfordcarriage.co.uk
http://www.botleytaxis.co.uk
transit4ever
Postby madmark » Tue Apr 03, 2007 12:18 pm
:? what about glueing it ??? some of these glues are fantastic like plastic weld ,or aroldite etc :?
Postby motorwise » Tue Apr 03, 2007 10:06 pm
madmark wrote::? what about glueing it ??? some of these glues are fantastic like plastic weld ,or aroldite etc :?
I agree - good glue or plastic weldint should do the trick - easy enough to change though :D
http://www.motorwise.net
motorwise
