Mk 6) TDDi or TDCi which is which ?
Postby ake » Fri Mar 25, 2011 9:01 pm
The Mk 6 Transit was available as both TDDi and TDCi depending upon the engine output
TDDi
FWD - 2.0 75ps 85ps 100ps
RWD - 2.4 75ps 90ps 115ps 120ps 125ps
TDCi
FWD - 2.0 125ps
RWD - 2.4 135ps
The main differance is that the TDDi uses a rotary pump and mechanical injectors, and the TDCi uses a high pressure pump, a common fuel rail and electronically controlled injectors.
It is very important that the TDCi models are fitted with the correct Ford fuel filter to prevent damage to the pump or injectors
Re: Mk 6) TDDi or TDCi which is which ?
Postby ian.welch.9404 » Fri Dec 19, 2014 10:37 am
My van has had a replacement engine. How can I check what engine they actually installed? Are there obvious visual difference or does anyone have pictures to id the two variants?
ian.welch.9404
Postby Altransit » Sat Dec 20, 2014 2:16 am
ian.welch.9404 wrote:My van has had a replacement engine. How can I check what engine they actually installed? Are there obvious visual difference or does anyone have pictures to id the two variants?
If you have electrical wires going to the injectors, then it's a TDCi :D
The engines aren't easily "switchable" so you're unlikely to find that the original has been swapped for the other type :wink:
Postby ian.welch.9404 » Sat Dec 20, 2014 1:36 pm
Cheers altransit for the education.
ian.welch.9404
Postby tam-sierra » Sat Jan 10, 2015 5:43 pm
ake wrote:The Mk 6 Transit was available as both TDDi and TDCi depending upon the engine output
TDDi
TDCi
FWD - 2.0 125ps
RWD - 2.4 135ps
mine is the 2.4 tddi but how do i know what power variant i have?
tam-sierra
Postby ake » Sun Jan 11, 2015 10:51 am
TDDi
TDCi
FWD - 2.0 125ps
RWD - 2.4 135ps
What's the reg number?
Postby tam-sierra » Sun Jan 11, 2015 5:27 pm
ake wrote:
TDDi
TDCi
FWD - 2.0 125ps
RWD - 2.4 135ps
SL51 TSX
tam-sierra
Postby ake » Sun Jan 11, 2015 6:14 pm
It's a 120ps.
I have posted the full details here :arrow: viewtopic.php?f=5&t=37058&p=1302991#p1302991
Postby tam-sierra » Sun Jan 11, 2015 6:53 pm
ake wrote:It's a 120ps.
thanks what does the 120ps mean? does that mean it has 120bhp? sorry im totally clueless on the whole ps kw i only know bhp lol
tam-sierra
Postby Altransit » Tue Jan 13, 2015 1:53 pm
PS is almost, but not quite the same, as BHP :mrgreen:
It's close enough to use as a guide though :D
Postby tam-sierra » Tue Jan 13, 2015 6:15 pm
Altransit wrote:PS is almost, but not quite the same, as BHP :mrgreen:
thanks for the info
tam-sierra
Postby Remix » Fri May 12, 2017 1:39 am
Thanks for the info...
been wondering what mine was since ive got it :)
Remix
Postby steve t » Fri May 12, 2017 12:29 pm
what year did they stop doing the tddi, after a work van and don't fancy common rail, thanks
steve t
Postby Altransit » Fri May 12, 2017 12:43 pm
They stopped at the end of the Mk6 production run in 2005/6.
All Mk7's are TDCi, but a different engine, and a more reliable fuel system.
Postby steve t » Fri May 12, 2017 5:23 pm
that's good, for some reason I thought they stopped in 03
steve t
cron
