hill start
Re: hill start
Postby loot » Wed Jan 14, 2015 8:16 pm
I never use the handbrake unless I'm on the steepest of hills, i drove up the hill stopped in gear, brake and clutch in out in out and moved off thinking ah f*ckit :-(
07 350 170ps
Ids map here
loot
Re: hill start
Postby mjsroofing » Wed Jan 14, 2015 8:48 pm
loot34 wrote:I never use the handbrake unless I'm on the steepest of hills, i drove up the hill stopped in gear, brake and clutch in out in out and moved off thinking ah f*ckit :-(
No, I never use hand brake, don't think I've ever done a "hill start" in a van.
Saying that I don't think I do in a car either.
I think it's from driving so many bangers years ago before I could afford a car that worked.
www.mjsroofing.co.uk
2022 2.0 ecoblue fwd, 72k
2009 2.2 tdci 115ps just over 110k now.
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Re: hill start
Postby loot » Thu Jan 15, 2015 5:51 pm
No dice :-(
Installed software for a later van.
Tried calibrating logitudinal sensor-routine failed.
Tried calibrating abs or something-failed
Calibrated steering angle sensor-success.
Downloaded vin data thing- success.
When it fails it is checking abs, the abs pump makes a noise, identical to bleed master.
It has to be a different abs pump/module as there's nothing else i can think of :? Can the yaw sensor be different?
Might just smash the hsa led so it stops winking at me when i start the van :roll: don't think it's worth replacing the abs pump.
Only other thing is that the vcm clone isn't capable of doing the process?
Bummer :cry:
07 350 170ps
Ids map here
loot
Re: hill start
Postby paul2012 » Thu Jan 15, 2015 6:29 pm
loot34 wrote:No dice :-(
Bummer :cry:
I know ABS pump is different to ABS/ESP. I will check against one with HSA.
In the mean time I have full ASAP built data & .ab file for mk7 2.2 115ps if you require it 8)
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: hill start
Postby loot » Thu Jan 15, 2015 6:52 pm
Cheers Paul :-) i got ab from a 140 exactly the same as mine but 08 with later clocks, only 1 byte different in the ab compared to mine which i wishfully thought was it lol.
Question, do all transits that come with abs/esp/later clocks 08 on have hsa? or the option to turn it on?
I also am wondering if i need to actually mod the abs data (install a calibration to it from a hsa pump?
If you could find out about the pumps tho Paul that would be great :-)
07 350 170ps
Ids map here
loot
Re: hill start
Postby walt1984 » Thu Jan 15, 2015 7:05 pm
Ours is a 61 and has hill start. Can't be turned on/off like connect.
57 plate didn't have it. Thing I noticed between the 2 vans, there is something like a solenoid on a brake pipe running down bulkhead under the servo. I don't know if itss any use ill post u a pic.
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Re: hill start
Postby loot » Thu Jan 15, 2015 7:11 pm
Yes please, anything that may help is good :-)
Just thought of something, my diagrams go upto 052008, i don't suppose anybody knows when hsa First came out? If it's after this date then i probably don't have the correct diagram :-(
07 350 170ps
Ids map here
loot
Re: hill start
Postby mjsroofing » Thu Jan 15, 2015 9:15 pm
Didn't it come out in 2009, same time as 6 speed box and 115 on fwd.
My m8s got same van as me but 2008 and it doesn't have hsa ,
mjsroofing
Re: hill start
Postby loot » Thu Jan 15, 2015 9:19 pm
A guy on here has said he has a 57 plate and hsa has stopped working so that takes it around 2008 i think.
I doubt it'll be fitted if the van doesn't have both abs and esp, don't ask me if they were both standard tho :?:
07 350 170ps
Ids map here
loot
Re: hill start
Postby loot » Thu Jan 15, 2015 9:23 pm
If i have a 2007 abs module then surely it'll be programmed without hsa? Can anyone say whether i can install abs data? And for a later calibration? Or will it have had the only available update for my van?
I wonder if it is just abs module data or is there extra components on the pump/system?
Walt mentioned an extra solenoid but it isn't listed in my diagram :-(
Would be cool to get to the bottom of this but if Paul doesn't find anything then just short of me pinching a van and striping it then I'm not sure lol
07 350 170ps
Ids map here
loot
Re: hill start
Postby paul2012 » Thu Jan 15, 2015 9:40 pm
loot34 wrote:If i have a 2007 abs module then surely it'll be programmed without hsa? Can anyone say whether i can install abs data? And for a later calibration? Or will it have had the only available update for my van?
After checking Ford Microcat....
If early 2007 mk7 don't HSA possibly reason why..
Lateral sensor was changed from 6C11-3C190 to 8C11-3C190 in 10/2007
Along with ABS/ESP pump from 6C11-2C405 to 8C11-2C405
NOTE - ABS/ESP pump is different between RWD & FWD :!:
paul2012
Re: hill start
Postby loot » Thu Jan 15, 2015 10:20 pm
OK thanks :-)
Think I'm going to have to do some drastic modification if i want hsa then.
Not going to be cost affective i think.
07 350 170ps
Ids map here
loot
Re: hill start
Postby mjsroofing » Thu Jan 15, 2015 10:29 pm
loot34 wrote:OK thanks :-)
Cost effective doesn't come in to it, it's a mod.
mjsroofing
Re: hill start
Postby walt1984 » Thu Jan 15, 2015 10:31 pm
walt1984 wrote:Ours is a 61 and has hill start. Can't be turned on/off like connect.
Don't think its brake related. I unplugged it and hsa still works. What ever it is it knew I'd unplugged it. Image
walt1984
Re: hill start
Postby loot » Thu Jan 15, 2015 10:43 pm
Aw guys i was getting used to the idea of letting it be and yous come and egg me on! :lol:
Abs pump on eBay 45 quid, lat sensor silly money.
Not sure what that sensor is Walt :-( yours fwd Is the sensor connected to the brakes? Or just located thereabouts.?
07 350 170ps
Ids map here
loot
