head lights
head lights
Postby thunderider » Sat Mar 31, 2007 2:16 pm
i got my van back after getting a new rad in it but the lights on the passangerside dont work,i found a broke orange green wire,side light i think connected it,still nothing,its got no main ,low,or side light bulbs seem ok fuses seem ok,are the two on seperate circutes/fuses.is the fuses the 2 red at the top of the box under the bonnet?
I am the god of hell fire.....
thunderider
Postby Nighthawk » Sun Apr 01, 2007 1:38 pm
is the lamp plugged in correctly?
while there is no reason to unplug the headlights to change the radiator, someone might have.
give the plug a sharp tug, if the wires come out of the back of the plug......it was plugged in and you've got a new fault ;)
Transit.........Job done
Nighthawk
Postby thunderider » Sun Apr 01, 2007 6:31 pm
it ws the plug they must have knocked it,but cus of broken wires and dodgey scotck locks i took the head lamp out,i also took the other side out and swapped them to test and the worked on either side,so just took the opertunity to put better wirein in for my spots :oops:
thanks anyway night hawk. :)
thunderider
