hill start
Re: hill start
Postby loot » Sun Jan 18, 2015 8:12 pm
Got the info for that :-)
But first I'm using the vin i got from an identical van as mine was before the mods except that it is 08 and abs/esp and later clocks, just to keep it simple :-)
I'm fairly certain it'll work on the new abs pump, another tricky thought is when i replace the abs pump, it's going to take a shed load of bleeding i think, i wonder do any of you have experience with bleed master? I assume i need my laptop in hand at each bleed nipple undo the nipple then activate bleed on ids then close nipple? Then work my way around? Not too sure of the procedure :oops:
07 350 170ps
Ids map here
loot
Re: hill start
Postby Punto443 » Sun Jan 18, 2015 8:44 pm
Do you have to swap the whole pump? Or can the electronics just be swapped?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: hill start
Postby paul2012 » Sun Jan 18, 2015 8:52 pm
loot34 wrote:Got the info for that :-)
IDS will provide instructions. It will most likely be the same as for connects. open both front bleed nipples first. Close when IDS promps you to, then do the same for the back.
PS:- Ideally you should have a brake bleed pressure bottle connect to brake reservoir & keep an eye on fluid level. It will drain fairly quickly :!:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: hill start
Postby paul2012 » Sun Jan 18, 2015 8:56 pm
Punto443 wrote:Do you have to swap the whole pump? Or can the electronics just be swapped?
As it's a different ABS/ESP pump replace complete unit :wink:
paul2012
Re: hill start
Postby loot » Sun Jan 18, 2015 9:11 pm
Will do :-) i clicked on bleed master once before and it pummeled the pump and said failed don't do that again :lol:
With all these failed tests lately i decided to check out my esp so went over the dual carriageway and gave it beans, the back end slid over and the esp kicked in 8)
Hopefully I'll know what's what once I've fitted the pump, I'll update then :-)
07 350 170ps
Ids map here
loot
oops
Postby loot » Tue Jan 20, 2015 7:34 pm
07 350 170ps
Ids map here
loot
Re: hill start
Postby loot » Tue Jan 20, 2015 7:41 pm
Gave the abs pump a clean and sprayed the motor bit in primer, would have finished it in matt black but someone has fleeced my 2 tin's of spay :?
I hate brake pipes and the brake pipe spanner, limited movement and impending doom as your brake fluid drips away, i know i should have emptied it out but i couldn't be bothered :lol:
Fortunately the pipes go up into the abs so the only fluid you lose is from the reservoir, i swore at and fitted the new pump and struggled with the brake unions but it went well.
I filled up the reservoir and that was it :shock:
Ideally you should remove the 2 large pipes on the left first then the 4 on top then refit the 2 left which fills the abs up then the 4 on top.
Once done, i got the boss to jump in and we went through the brake bleed procedure, next to nothing came from the front caliper nipples, i left the back.
I will do an ids service bleed later on.
In ids i checked for fault codes and got this.
It is different to the last time before i fitted the new abs unit. :-)
I went to module installation and install abs and it ran then said install new module (usually you have your original then run them when it reads install new module you then install the new 1 but usually through that, ids copies the data from the first 1 and pastes it onto the new 1, mine being no good i did it all on the new 1 in the assumption that it copies the new 1 to the new 1 but integrating it with my van/whether that makes an ounce of difference i don't know, or care :lol:
Then i had a look at the system and calibrated the longitudinal sensor and steering sensor and turned on hill start assist.
For the record, abs is a dumb module, just wants initialising and calibrating. :-)
And on the way home....
Tadaaaaaaa 8)
Thanks to paul for his help with thrashing out a solution.
Thanks to punto for his help with parts
And thanks anyone else who contributed.
8)
What shall i do next then :mrgreen:
07 350 170ps
Ids map here
loot
Re: hill start
Postby martynx » Tue Jan 20, 2015 7:54 pm
Well done Geyser :)
martynx
Re: hill start
Postby Punto443 » Tue Jan 20, 2015 7:55 pm
Aircon
Heated seats
Touring car single wiper, with centre screen park
Air ride suspension
AWD conversion
Heated washer jets
Headlamp washers
:lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: hill start
Postby paul2012 » Tue Jan 20, 2015 7:58 pm
loot34 wrote:And on the way home....
Tadaaaaaaa 8)
8)
There you go, now you have HSA 8)
Next mod, turbine engine in the back :?: :lol: :lol:
paul2012
Re: hill start
Postby karl » Tue Jan 20, 2015 8:03 pm
loot34 wrote:Gave the abs pump a clean and sprayed the motor bit in primer, would have finished it in matt black but someone has fleeced my 2 tin's of spay :?
Tadaaaaaaa 8)
8)
all i have to say is you are one cleaver f*** :lol:
karl
Tranny Lover!!!
Re: hill start
Postby loot » Tue Jan 20, 2015 8:09 pm
Ah good man punts:-)
I have washer jets that clip onto the wiper arm but they're not very pretty but i noticed the ones on the iveco daily today look cool, but they look connected to the wiper blade :shock:
I'll get some heated seat pads sometime, looking at the wiring diagram they are plug and play, the switches have thermal protection, do they go off after a while or are the switches not momentary? Do you turn them on and the switch cuts them out??
Not into single wiper tbh:-(
Heated yes :-)
Air con.... Fook that have you seen the wiring diagram? I could do it but the hassle for gains just isn't worth it for me I'm afraid, besides if i want to feel the cold in my van I'll pick on the mrs :lol:
Awd of love that 8) could be fairly simple, if i could get the bits, my can is always empty so the back end slides out going over the road in wet etc :-(
Headlamp washers hmm i like, but I'd have to have wipers wouldn't i?
Ohh i like ideas :-)
Still waiting for my halo projectors then i can crack on with my light mod.
Painting and sport Kit wants fitting too :roll:
07 350 170ps
Ids map here
loot
Re: hill start
Postby ake » Tue Jan 20, 2015 8:13 pm
Well done Mr Loot sir, you really are a geek :)
Re: hill start
Postby loot » Tue Jan 20, 2015 8:13 pm
Paul: There you go, now you have HSA 8)
Lol but where would my wrappers and unfinished bits go? :lol:
Karl: all i have to say is you are one cleaver f*** :lol:
Thanks lol
So glad you didn't put something else in place of clever :lol:
07 350 170ps
Ids map here
loot
Re: hill start
Postby loot » Tue Jan 20, 2015 8:15 pm
ake wrote:Well done Mr Loot sir, you really are a geek :)
Thanks m8 :-)
I've still got your thing on my list to do, damn cold weather tho :oops:
07 350 170ps
Ids map here
loot
Users browsing this forum: Bing [Bot], Majestic-12 [Bot]
