ABS and Airbag Help
ABS and Airbag Help
Postby Dan T » Wed Apr 04, 2007 8:06 pm
2002 02 SWB 2.0L
Since replacing the missing ABS and Airbag bulbs they are constantly on. My airbag light reads a fault code 5.
The van has been plugged for faults but comes back with nothing, i'm lost for next steps.
any suggestions would be a huge help.
Dan T
Postby Nighthawk » Wed Apr 04, 2007 9:07 pm
Can you recheck your fault code, it should be 2 digits :)
it could be
15.........Driver air bag circuit shorted
or
35........Passenger air bag circuit resistance low
check it and i can help further :)
Transit.........Job done
Nighthawk
ABS and Airbag Help
Postby Dan T » Thu Apr 05, 2007 12:29 am
The Light flashes 5 times then a 2 second gap then flashes 5 times then a 2 second gap then flashes another 5 times... (this goes on for a few minutes)
Dan T
Postby Nighthawk » Fri Apr 06, 2007 6:53 pm
Hi
I think you need to take your vehicle to a dealer for a complete diagnostic check on the airbag system
there isn't a 5 flash code.
When WDS or IDS is used to diagnose the system in a workshop, it'll read out the full fault code.
e.g. flash code 32 would be read off by the diagnostic equipment as B1932
Sometimes if a module becomes U/S they can flash out random codes, 1 particular code for crash data memory full requires the module to be replaced as it's an un deleteable code.
Nighthawk
