Idiots guide to IDS
Re: Idiots guide to IDS
Postby loot » Wed Feb 11, 2015 9:53 pm
Glad to help :-)
07 350 170ps
Ids map here
loot
Postby Wadey » Wed Feb 11, 2015 10:11 pm
The msn is a legend I wouldn't even know where to start if it wasn't for him and iv not even got ids into my computer yet!
just follow the onscreen instructions and it's fairly idiot proof...trouble is, we keep producing better idiots
Wadey
Postby loot » Wed Feb 11, 2015 11:10 pm
How you getting on with yours? :P
07 350 170ps
Ids map here
loot
Postby Wadey » Thu Feb 12, 2015 12:30 am
I'm waiting for the windows 7 disk iv been offered
Wadey
Postby tibsy » Thu Feb 12, 2015 4:29 pm
just been out to have a proper play with my vcm 2 .
did a load of prelimary checks,
dtc`s
pedal
fan
engine warm up
turbo
injector
vss
all pass except vss (null module, so doesn`t apply to mine)
but i`ll be buggered if i can find the part of menu to do a pump/pilot learn and pcm update.
is "injection correction factors" where it is at?
mk7,60 plate,2.4-115ps-hirf lwb rwd
The words of the Prophet`s are written on the subway walls
tibsy
Postby loot » Thu Feb 12, 2015 5:08 pm
Do you have a mk7?
Go to engine- service functions and it will be there, top option is code injectors, 2nd is fuel pump pilot learn, 3rd is injectors pilot lean etc.
Pcm update is, module programming-module reprogramming-pcm, and it'll tell you if there is an update available.
:o
07 350 170ps
Ids map here
loot
Postby tibsy » Thu Feb 12, 2015 5:15 pm
loot wrote:Do you have a mk7?
:o
yes, a 115ps 2.4 60 plate.
cant find- "engine" in the menu? do you mean powertrain?
bloody hell, i`ve now found it.
when i saw service functions earlier and then pcm,-i never clicked on pcm :oops:
tibsy
Postby loot » Thu Feb 12, 2015 5:33 pm
Cool, yes was power train lol, it's best when I'm actually looking at the menus :-)
07 350 170ps
Ids map here
loot
Postby paul2012 » Thu Feb 12, 2015 5:50 pm
Window 7 professional 32bit with SP1 DVD anyone :?:
I have a stack on them (50+) :lol:
Free to anyone who wants one 8)
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby tibsy » Thu Feb 12, 2015 7:04 pm
from start to finish, how long does it take (roughly) to do the pump/pilot learn and pcm update?
reason for asking is i need to know whether i need to run 240v leads (2 leads actually as the van is parked in the street)out to the van to plug laptop charger in as i dont want the laptop dying on me halfway through!. still unsure as to how good the laptop battery is!
if the learn/updates only take a few mins it should be ok, but any longer and i`ll have to run the leads out :)
tibsy
Postby loot » Thu Feb 12, 2015 7:47 pm
They are separate functions, you are always advised to have the van battery on charge and it goes without saying that the laptop wants to fully charged, on charge or with a good battery.
That said, I never put my van on charge, partly because I'm a rebel and partly because I have new batteries. :mrgreen:
Anyway, the pcm update only takes a maximum of 15 mins iirc.
The pump learn takes longer.
The injectors learn takes longer too.
You should put a charger on your laptop tbh, you could fully charge it and play a film to see how long it lasts off charge, you could do 1 operation at a time and recharge the laptop in between.
Bit crazy tho :o
07 350 170ps
Ids map here
loot
Postby tibsy » Thu Feb 12, 2015 8:07 pm
ok, i`ll run the leads out then to be on the safe side!
van batteries are both new (well 3 months old -"varta f18`s"), so they should be ok :D
do you normally get the engine up to "working" temp first or doesn`t it matter? thanks
tibsy
Postby Wadey » Thu Feb 12, 2015 8:30 pm
paul2012 wrote:Window 7 professional 32bit with SP1 DVD anyone :?:
I'm not sure on whats happening with regards matey sending me one but I'll bear it in mind
Wadey
Postby 2tall » Thu Feb 12, 2015 8:38 pm
tibsy wrote:do you normally get the engine up to "working" temp first or doesn`t it matter? thanks
The engine needs to reach the operating temperature for the pump/pilot learn, IDS will guide you through that.
It takes a while though, maybe 30–45 minutes if you start with a cold engine.
Just did it first time a couple of weeks ago late at night and pissed off all the neighbours.
Didn't have a clue how long it would take when I started :mrgreen:
2tall
Postby tibsy » Thu Feb 12, 2015 9:17 pm
ok, cheers for that :)
tibsy
