AlanN's MK3 V6 Day Van
Re: AlanN's MK3 V6 Day Van
Postby Leeday » Fri Feb 13, 2015 10:00 pm
MinorMatt wrote:Its the DVSA ;) VOSA don't exist anymore
Its only since October 2012 that the IVA applies :wink:
The last trailer I built was finished in September 2012 (No honestly it was... i'm not making it up, it was moving cars in October)
I would be looking to use a trailer axle rather than a transit axle because you will get brakes that work properly with auto reverse...
VOSA don`t exist anymore :shock: ha, I`ve been so busy trying to get my van working for the past ... ages, that I missed that :lol:
Agreed, trailer axle would be far easier :D could even get a stripped caravan trailer and adapt it to fit the transit body on, would sort out loads of issues.
1989 Mk3 swb, 3.0 V6 Essex, 5 Speed Manual: http://fordtransit.org/forum/viewtopic. ... 3&t=142054
2005 Mk6 2.0 Duratorq 100 T350 MWB Semi High
Leeday
Postby paul2012 » Fri Feb 13, 2015 11:23 pm
Yes DVSA (Driver and Vehicle Standards Agency) replaced DSA & VOSA :wink:
IVA inspection fees for trailers depend on axle weight.
01 - axle weight up to 750kg - £70
02 - axle weight from 750kg to 3500kg - £70
03 - axle weight over 3.5t to 10t - £145
If trailer is deemed non-compliant. Re-inspection fee is £14 for 01 & 02 trailers, £29 for 03 & 04 trailers
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby AlanN » Sat Feb 14, 2015 8:44 pm
So for a home build, im gonna have to have a IVA test. Could all get a bit complicated.
I had thought about a caravan or similar to build it on and have hub adapters made or redrills for the wheels but i wanted to keep the rims all the same so they can be swapped if necessary.
Postby Luke » Sat Feb 14, 2015 9:13 pm
not if you use a caravan chassis or just say it was built years ago - you'd proberbly be able to redrill the caravan hubs :D
Postby Leeday » Sat Feb 14, 2015 11:05 pm
Older caravan chassis were made of steel (1960, 70 & 80`s), so welding to your mk3 rear ends real easy, later caravan chassis (1990 onwards) were `Alko` alloy chassis so not so easy to weld to steel and usually have caravan bodies bolted to them :D
Leeday
Postby ROVER-25X » Sun Feb 15, 2015 1:42 am
Great project though.
How about a twin axle trailer for giggles. :D
ROVER-25X
Postby AlanN » Tue Feb 17, 2015 9:45 pm
not sure it would suit my little swb, but that has to be a project for someone with a twin wheeler
Postby robbie.cee » Sat Mar 07, 2015 5:35 pm
Just found this old mock up for my trailer, means making another roof spoiler and a couple of sets of lights, although I have collected a few parts for doing the job, wheels and tyres, new arch panels etc. its a way off yet. Need to find myself some space to make it in<br />Image<br /><br/>
Make 2 and you can do it in my garden lol
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sat Mar 07, 2015 5:37 pm
Just make sure one is green ;-)
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Sat Mar 07, 2015 5:38 pm
Lol if we could find 2 sets of rear ends, I might take you up on that one day
Postby AlanN » Sat Jun 20, 2015 6:35 pm
Van has been off the road for some months while I tidy things up a bit. Cleaned up the engine bay, a lick of paint and sort out the wiring. Pulled most of the ancillaries off to get good access and hand painted the bay, plus repainted a few bits. Image
Also thought it was about time to fit the headlight washer bottle, pipework and pump. When I fitted the injection metering head, it had to go where the wash bottle was, so I moved the bottle on the other side of the bay. The Mk3 headlight/screen bottle is so much bigger and just wouldn't fit in the space, so I tried a Mk4 bottle, success! Just a little smaller, it fitted reasonably well
Pipework was fitted to grille jets and I couldn't use the reinforcement brackets due to my modified grille, but seemed sturdy enough.
The headlight pump only works when the headlights are switched on, so a relay was wired in.
Sadly, I haven't tested them yet due to my next BIG problem...
Postby AlanN » Sat Jun 20, 2015 7:03 pm
The BIG problem... with the show season starting with North Weald in a few weeks, I noticed a thin rust crack in the paint of the front cross member, so I thought a little poke with a screwdriver would show a break in the paint.... No! You know whats coming now, don't you!!! Nearly lost my bl**dy hand as the screwdriver disappeared into the section!
Yes rotten, so I had a good look over and it seemed to be the only area affected, but had to come off, quite easy using a spot weld drill, only took a couple of hours, great I thought!
A quick test fit and after a little fettling all looks good, oh no, not yet, that doesn't doesn't happen in the real world...
Postby madbri » Sat Jun 20, 2015 7:04 pm
no water :lol: :lol: :lol:
madbri
Postby AlanN » Sat Jun 20, 2015 7:06 pm
I wish it was that simple lol
Postby madbri » Sat Jun 20, 2015 10:42 pm
i spy classic mini :mrgreen: :mrgreen:
madbri
