Fuses, Bl~~dy fuses on an 08 connect
Postby stehanson » Sun Mar 22, 2015 1:24 am
Having a nightmare with my Engine compartment fuse box in so much as the diagram appears to differ from the box itself and the diagram has 12 rows with fuses populated in rows 1 and 12, however the box itself only has 11 rows ..... arghhhh :o
Theres no numbers on the box so it's kind of guesswork as to whether the top or bottom row (left or right side in pic) is the missing row so it's hard to work it out
F42 is present and working so im guessing the row thats not there is the far right one in the fuse diagram pic, but....
I have two problems im trying to cure (3/4 other issues)
1) cig lighter is not working, i'm guessing the fuse has blown as a sat nav lead fell apart in it and prob shorted it out in doing so.
2) the reverse lamp is not working, though the bulb is fine (could be the switch rather than the fuse though) f41 in the fuse diagram but that row appears notto be in the fusebox????
3) going off the diagram many fuses are the incorrect ampage?
4) f47 has a 20a fuse but its listed on diagram as heated seats (mine has no heated seats) f46 is windscreen wipers in diagram on box it appears empty, but the f47 (from diagram)has a 20a fuse and windscreen wipers work??
Anyone had similar issues and can offer advice on this?
Someone please help before I lose my mind completely!!
stehanson
Re: Fuses, Bl~~dy fuses on an 08 connect
Postby liteace » Sun Mar 22, 2015 10:04 am
Thats not the Engine compartment fuse box as its inside its the passenger compartment fuse box, looks like wrong cover \ sticker \ info
1st row, top left (blue 15 amp) is fuse 30 running along to fuse 40
2nd row 41 to 51
3rd row 52 to 62
fuse 43 (15a) is your cig lighter & fuse 41 (10a) is reverse lamps
Please don't send me PM's, i can't access them, when I try I get this:
You are not authorised to send private messages
liteace
Postby stehanson » Sun Mar 22, 2015 11:20 am
Sorry typo meant to write central fuse box... that's how irate it's now got me I'm now confusing myself ☺
Thanks for the info, Is there anyway of finding out the correct layout in terms of a picture if mine may be incorrect?
I have other items to add in to the equation soon... A dash cam and a screen first to be hardwired via a fuse tap, (live lead) black ground (black) to be added somewhere that's already used for this. Screen not sure if it will be same or plugged into cig lighter yet.
So what free fuse positions are only live when ignition is on for this purpose (only want cam running from van battery when engine is running)
Many thanks
stehanson
Postby liteace » Sun Mar 22, 2015 11:46 am
I wired my dash cam and screen into the radio feed as you have it all there, live, earth + ign feed
liteace
Postby stehanson » Sun Mar 22, 2015 12:10 pm
Auto electrician I am not lol, the hardwire kit that came with the cam from joovuu has a red and black lead only so a fuse tap for red and ground the black to an earth point was my easy option!
Not having a clue about auto electrics I would have thought your method would involve 3 wires and perhaps splicing into existing wires. ..A sire thumb just guessing here?
What screen did you get? Looked at so many mirror mounted ones, but think the 7" may hang a little low from my existing mirror and stick out like a sore thumb!
stehanson
Postby liteace » Sun Mar 22, 2015 12:22 pm
Yes I did splice into ign feed for radio wiring as that is already fuse protected for camera and screen and also spliced into the live, again fuse protected for the DVR
I removed one of the center air vents and the small 4.5 inch screen sits in there
viewtopic.php?f=54&t=122358&start=15#p1012388
liteace
Postby lightning » Mon Mar 23, 2015 9:29 pm
My 2008 Connect was the same, the fuse box sticker was completely wrong, l ordered another sticker from Ford and that was wrong too
lightning
Postby stehanson » Fri Mar 27, 2015 4:40 pm
lightning wrote:My 2008 Connect was the same, the fuse box sticker was completely wrong, l ordered another sticker from Ford and that was wrong too
Lol, I was going to do that myself till I read on another thread someone had done that and it was still incorrect!
Anyone got a full list or pic of passenger fuse box locations for an 08 connect ...for future reference?
stehanson
Postby John235 » Sun Mar 29, 2015 10:59 am
My 08 plate has the 11 row fusebox. I have managed to glean some info, from Haynes, also from owners handbook.
I have generated an excel spreadsheet, but there does not seem to be a way to attach it. If you PM me, I can forward it by email.
John235
Postby John235 » Sun Mar 29, 2015 11:10 am
Let's try something!
F40 F51 F62
1 15A 7.5A
Airbag
F39 F50 F61
2 7.5A 15A 7.5A
Int Lights Rear Acc Conn ABS
F38 F49 F60
3 15A 7.5A
Aircon/Heat Screen
F37 F48 F59
4 5A 7.5A
Relay Panel F36 F47 F58
5 10A 7.5A
Heat Seats Light Switch
F35 F46 F57
6 20A 7.5A
Front Wiper Side/Tail
F34 F45 F56
7 7.5A 20A 7.5A
Heat Mirrors Rear Wiper Side/Tail
F33 F44 F55
8 25A 7.5A
Rear Win Side/Tail
F32 F43 F54
9 10A 15A 25A
Light Sw Front Acc Conn1 Elec Win
F31 F42 F53
10 5A 15A
Elec Mirrors Stop Lights
F30 F41 F52
11 15A 10A
Rev Lights
Ford Owners Handbook
F40 Audio Sys Acc
F31 Audio Sys Mem & Power
F48 Hazard/Door Lock/Immobiliser
F61 Indicator/Door Lock
Ah, the excel formatting does not transfer!
The chart above is from a spreadsheet I have produced, mainly from the Haynes book, also from the drivers handbook.
The detail & layout have changed a bit, due to copy/paste, but the outline is there. If anyone wants the full monty, send a PM & I can forward it as a spreadsheet. There is also info on the diagnostic connector & the 6000 series radio plugs.
John235
Postby John235 » Mon Mar 30, 2015 11:48 am
Let's see if this works!
I've converted from excel to jpeg.
John235
Postby stehanson » Tue Mar 31, 2015 12:43 am
John235 wrote:Let's see if this works!
You my friend deserve a pint for the last few posts, Thank you very much!
just come on to see if anyone had replied over last few days and saw the post to pm you, then this one!
Ill pm you for the raw excel but the pic is fine for what I need now!
Thanks again!
stehanson
Postby stehanson » Tue Mar 31, 2015 12:53 am
Now to find which fuses are not hot all the time (go off with ignition) I sense another headache coming tomorrow as i'm off and the rear view mirror screen arrived today,
Thats the cctv (always live rear view cam), the dashcam and the screen to wire in tomorrow, Im sure connecting then hiding all those cables in headlining and A pillar will be fun.... afterall the inverter was a doddle to connect ( 1 cigarette lead lol :D )
stehanson
Postby Kimifa » Fri Oct 16, 2020 5:36 pm
John235 wrote:My 08 plate has the 11 row fusebox. I have managed to glean some info, from Haynes, also from owners handbook.
Hey, I know this is 5 years old now, but I've got the same issue (incorrect sticker under glove box) and it seems this Excel file would be just what I need. Any chance I could get it from you? I wanted to PM but not sure how and couldn't find any way to do it lol
Kimifa
Postby Altransit » Sat Oct 17, 2020 11:03 am
Kimifa wrote: Any chance I could get it from you? I wanted to PM but not sure how and couldn't find any way to do it lol
The file is attached to his post, 3 posts up 8)
You're unable to PM other members until you've made more posts :)
