another keyfob ?
another keyfob ?
Postby scotiaredd » Sat Apr 14, 2007 4:56 pm
M6 2001
Ive looked at the links on reprogramming the fob. Ive replaced the battery's and also followed the instructions on reprogramming ie: ignition of on 8 times etc... But still the fob wont work. Few Questions...
Do i Draw the line there?
Buy another fob of crimebay?
Or is it something.else in the system?
Cheers...
GET OF ME TRANNY YA SCUM, OR AL SHOOT YE!!!
scotiaredd
Postby motorwise » Sat Apr 14, 2007 5:01 pm
are you doing the ignition cycles within ten seconds?
http://www.motorwise.net
motorwise
Postby scotiaredd » Sat Apr 14, 2007 5:16 pm
whats u mean. ignition of on for 8 times then press buton on the fob. ie
Before a new remote control can be used, it must be programmed. Up to four remote controls can be programmed.
To carry out the programming, the ignition key must be turned to position RUN and back to position OFF four times within 6 seconds.
The ignition is now switched off and the control module is in the programming mode for 10 seconds. This is indicated by illumination of the LED in the digital clock or by locking/unlocking.
Now a button on the remote control should be pressed. The remote control signal, if accepted by the control module, makes the LED in the digital clock flash or locking/unlocking occurs.
The next remote control must be programmed within the next 10 seconds.
The programming mode is terminated if no further remote control is programmed within 10 seconds or the ignition is switched on. The LED is no longer illuminated after termination of the programming mode.
STILL NO LUCK :cry:
scotiaredd
Postby motorwise » Sun Apr 15, 2007 12:44 pm
getting me seconds mixed up - when you do the cycling of the ignition do the doors run through a lock/unlock cycle?
motorwise
Postby scotiaredd » Sun Apr 15, 2007 7:57 pm
the doors run through the cycle, yes...
scotiaredd
Postby motorwise » Sun Apr 15, 2007 7:58 pm
scotiaredd wrote:the doors run through the cycle, yes...
sounds like your remotes at fault then
motorwise
Postby scotiaredd » Sun Apr 15, 2007 8:28 pm
cheers. so you recommend buying another keyfob?
scotiaredd
Postby motorwise » Sun Apr 15, 2007 9:20 pm
scotiaredd wrote:cheers. so you recommend buying another keyfob?
I think thats what I'd do next - loads cheap on e bay
motorwise
Postby scotiaredd » Mon Apr 16, 2007 7:56 am
cheers for that, i will sort that out next...
scotiaredd
