T330 3.2 24v v6 Project/Idea
Postby mrrcarney » Sun May 10, 2015 6:38 pm
Ok had a brainwave the other day
and after some thinking this is my idea
My van has the 2.4 TDDI and its a bit boring to say the least with its massive 90hp now I want this van for pure leisure so its also gonna be made look good sound good and be kinda quick but still be able to drag a car trailer
But its going to be on a budget
I considered the 6bta like the man of the scania is doing but after some crude measurements without losing a leg and a clutch pedal it would be tight and rather warm with the turbo sitting about an inch away from my left knee
so my next thought was a v8 but without spending an arm and a leg its going to be crap on the power side
so my next thought was a v6 and I happen to know a thing or 2 about the GM v6 found in vauxhalls I have seen this posted a few times on here but never seen it done so I like to be different and I also happen to know this engine very well and have a load of parts for them in my (I will use it one day junk yard horde of vectra gsi bits)
so the plans so far
omega v6 3.0 intake manifold and throttle bodies
vectra / omega 3.2 engine
4x G cams from the vectra Gsi
Cool running stat
custom 3-1 exhaust manifolds and custom downpipes
omega ecu etc
transit gear box (plate needed dieselhead to make the v6 fit)
lightened flywheel and competition clutch
I had 7 vectra Gsis all at once a few years back and converted most of them to the 3.2 my personal daily was running 240hp and kept eating the gearbox and clutch (mostly 2nd gear)
not sure if I should go for an aftermarket ecu at the moment as I fancy a turbo setup eventually
give me your thoughts and concerns
cheers rob
ps. how can i tag people in the post ?
mrrcarney
Re: T330 3.2 24v v6 Project/Idea
Postby Luke » Sun May 10, 2015 7:25 pm
i like the idea :mrgreen: :mrgreen:
have a read through this for some ideas viewtopic.php?f=27&t=26031 i would think the V6 would fit in without any worries :D
Postby mrrcarney » Sun May 10, 2015 8:22 pm
Luke wrote:i like the idea :mrgreen: :mrgreen:
cheers mate love that Yb van
I think it should fit only place I think it would be a bit tight is the bulk head with the heads
and my only concern is the ecu and wiring to be fair as i am struggling to find a cable throttle 2.5 so may need to use the fly by system
mrrcarney
Postby Luke » Sun May 10, 2015 10:02 pm
ive not yet done a swap with a fly-by-wire throttle - but i'm doing one now, all i'm going to do is use the donor pedal mod it to suit the transit floor :D
with the wiring if you can get a decent wiring diagram your half way there :D
Postby mrrcarney » Sun May 10, 2015 10:15 pm
Luke wrote:ive not yet done a swap with a fly-by-wire throttle - but i'm doing one now, all i'm going to do is use the donor pedal mod it to suit the transit floor :D
well I am going to buy a full omega to gut so that can be done lol
as for wiring diags best place to look ? I want most of it planned the winging it part comes when I am making the mounts and the exhaust manifolds :lol:
cheers rob
mrrcarney
Postby Luke » Sun May 10, 2015 10:28 pm
best bet would be vauxhall omega forums - the one im doing now (with the fly by wire) is a vw passat and the best wiring diagram ive got so far is our of the haynes manual :D
my plan with this one is pull the wiring out (thats how far ive got) then thin it out getting rid of all the unnecessary stuff (abs lights etc.) then refit it back to the car check it runs ok then pull the engine out and fit it in the van :D
Postby mrrcarney » Sun May 10, 2015 11:41 pm
thats a really good idea !
abs airbags etc :D
mrrcarney
Postby thismustbeathursday » Mon May 11, 2015 5:40 pm
Whilst this may sound a little random, have a look on the forum for Scimitars, http://www.scimitarweb.co.uk/sgwrs/viewforum.php?f=20.
There are a few projects there where they've replaced the Essex with the 3.2 Omega engine. There should at least be some indication of where to get wiring diagrams and similar if nothing else.
thismustbeathursday
Postby Shitlaptop » Mon May 11, 2015 6:00 pm
cheers rob
Ive just sold my 2.6 V6 Omega on a 51 plate...stonking motor and bloody great condition.
Had to sell it as had heart set on a Tranny again...let mate have it for £300.
As suggested the Omega forum is very helpful...just post in the right section and I can assure you will get an awful lot of good advice,they know there cars inside out and I mean that quite literaly.
Hope mods don't object http://www.omegaowners.com/forum/
Shitlaptop
Postby mrrcarney » Mon May 11, 2015 8:08 pm
Cheers guys can't wait for my new car on the 18th so it can be put off the road and stripped
mrrcarney
Postby dieselhead123 » Mon May 11, 2015 8:33 pm
Hi there, should be a good conversion, more powerful than the BOB and a simpler 'engine only' ECU management system :D
I have CADs for the Duratorq and the GMV6 so could easily sort out an adapter plate.
If you do decide to go this route, all I would need is a block/crank and flywheel to get the clutch 'offset' correct, possibly a bellhousing to get the starter positioning correct.
Good luck fella 8)
Postby mrrcarney » Mon May 11, 2015 11:16 pm
I most likely have a block sitting lol
But I will be buying a 3..2 engine and a 2.5/6 so having a spare laying about anyway
Pm me rough price mark for a plate cheers
mrrcarney
Postby bigyellow » Wed Aug 12, 2015 10:31 am
did you get any further with this idea as i think it was amazing to do
bigyellow
Postby stuvy » Wed Aug 12, 2015 11:11 am
Buy a vivaro and do it but don't put a vauxhall engine in a ford
It's like non alcoholic beer and licking your sisters pussy. It tastes the same but it's just not right...
stuvy
Postby walt1984 » Wed Aug 12, 2015 11:43 am
And on that bomb shell we await bjts comments.
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
