MK7 Ford Transit left front door rubber seal, where to buy?
Postby pp5858 » Wed May 20, 2015 9:18 am
Hi,
My left passenger side front door rubber seals are really worn out, but I haven't found out proper place to purchase ready made seals or by meters the proper seal.
There is a lot of discussion on this but still didn't find specificly where to buy and what seal?
pp5858
Re: MK7 Ford Transit left front door rubber seal, where to b
Postby stevo » Wed May 20, 2015 9:37 am
Local breakers may be the best bet if you have one local. Other than that have you tried a ford dealer?
Formely ibanez2005
2003 100 T260 TDDi swb
stevo
Postby loot » Wed May 20, 2015 12:24 pm
As above, presumably you mean the whole door seal rather than the gutter 1.
They come up on eBay sometimes for around 40 pounds.
Ford may be a lot more?
Breakers would be cheaper plus you can inspect it all the way round for rips, you'd be surprised hoe many internet sellers tell you it is mint only to find it has kinks and rips all over the place (second hand).
Mk7 is different to mk6 too.
Apparently new ones fit either side.
Would be cool to buy it in lengths, let has know if you find anywhere that does it :o
07 350 170ps
Ids map here
loot
Postby stevo » Wed May 20, 2015 12:43 pm
loot wrote:As above, presumably you mean the whole door seal rather than the gutter 1.
I thought ford would be expensive for a door moulding I needed but it wasn't really that bad. As a set they are expensive but it was around 40 quid for the side loading door one. Got to be worth a ring, can also get the part number off them.
Formely ibanez2005
stevo
Postby loot » Wed May 20, 2015 1:26 pm
<20708 1431919 Weatherstrip - Door Opening
<20708 1555296 Weatherstrip - Door Opening
07 350 170ps
Ids map here
loot
