FWD to RWD
FWD to RWD
Postby Mr RVM » Wed May 27, 2015 1:17 pm
A quick question to those that know (I don't :oops: ) can a Mk7 FWD body shell be converted to accept RWD running gear :?: is the bulkhead and floor pan the same (or drastically different) :?: and rear spring mounts :?:
I know that this COULD be done, but is it fairly straightforward or more bother than its worth :?:
Cheers in advance
PS just spoke to Karl and its a No No :( (Back to plan A then :roll: )
Mr RVM
Re: FWD to RWD
Postby loot » Wed May 27, 2015 5:53 pm
I agree, rwd has less floor height on the chassis.
You could probably make a bigfoot tho 8)
07 350 170ps
Ids map here
loot
Re: FWD to RWD
Postby Punto443 » Wed May 27, 2015 6:13 pm
Bulkheads the same, but the rear floor from behind the cab is 4" higher on a rwd,
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: FWD to RWD
Postby Mr RVM » Thu May 28, 2015 2:52 am
loot wrote:I agree, rwd has less floor height on the chassis.
Hmmm needs more investigation :wink:
Mr RVM
