02 transit crewcab tipper 90 bhp more power!!!
Postby LutonStu » Wed May 27, 2015 9:29 pm
hi all could anybody tell me how to get more power out of it. and i have a 125 diff can i put that in as mine is whining cheers stuart...
LutonStu
Re: 02 transit crewcab tipper 90 bhp more power!!!
Postby Gonzo330 » Thu May 28, 2015 6:39 am
From information I have gleaned, one needs to talk to vantuner for a remap, block off your EGR valve, clean out the intake manifold, fit a K&N, and wind the boost up by 2-3psi for starters.
I'm led to believe 125 injectors are, essentially, a bolt-in upgrade, but until I get hold of a set myself, I can neither confirm nor deny this.
I drink too much, I swear too much, I drive too fast and I crash too often.
It is a universal impossibility for me to leave my tools alone. Everything can be made to go faster!
Gonzo330
Postby ake » Thu May 28, 2015 8:16 pm
Yes you can use the 125 diff, but you'll need a bit more power to keep it moving when loaded
Postby LutonStu » Fri May 29, 2015 12:07 am
Hi thanks for the reply.s I have a 125 that's got a brand new head diff gearbox and other bits to.if anyone's interested the head will be up for sale. So I can just put the injectors in my van and it will run or do they need coding to my van?
LutonStu
Postby ake » Fri May 29, 2015 7:15 am
LutonStu wrote:Hi thanks for the reply.s I have a 125 that's got a brand new head diff gearbox and other bits to.if anyone's interested the head will be up for sale. So I can just put the injectors in my van and it will run or do they need coding to my van?
Injectors will go in, but it'll still be 90 ps because the pumps are different, and the ecu is set up as 90 ps.
You would need to get it remapped, or change to a mechanical pump then tune it up a bit
Postby LutonStu » Fri May 29, 2015 8:59 am
Right ok. I.m gonna get vantuner to sort my ecu out and see what it does then thanks for the help stuart I. Ll let you.s no how I get on.. Thanks again..
LutonStu
Users browsing this forum: knobby1
