toms mk7 sport rep
Re: toms mk7 sport rep
Postby glenandemm » Thu May 21, 2015 5:24 pm
one of the nicest transits ive seen pal, can i ask where you got the rear lowered leafs from and how did you lower the front end, springs? im thinking about dropping my strut through the hub a tad more!
glenandemm
Postby Perfectpaintwork » Sat May 23, 2015 11:35 pm
thanks for all the comments, it did turn out nice. sold it now as I just moved to Australia so time to start again will post pics of new van shortly its a 2010 swb 115 280 6 speed needs a bit of bodywork, just started ordering some bits from uk as not much out here.
Perfectpaintwork
Postby Perfectpaintwork » Sat May 23, 2015 11:37 pm
glenandemm wrote:one of the nicest transits ive seen pal, can i ask where you got the rear lowered leafs from and how did you lower the front end, springs? im thinking about dropping my strut through the hub a tad more!
the front was on custom made springs by coilsprings.co.uk cost about 140 delivered
rear where straightened by owen springs
I recommend both companys they were very good
Perfectpaintwork
Postby tourneo newbie » Thu May 28, 2015 8:53 pm
What wheels are those they look like bmw ones? If so did you use hubcentric adapters to fit them
tourneo newbie
Postby Perfectpaintwork » Fri May 29, 2015 11:04 pm
tourneo newbie wrote:What wheels are those they look like bmw ones? If so did you use hubcentric adapters to fit them
they are 20" jaguar kasuga alloys, front hubs were redrilled and rears were on hub adaptors
Perfectpaintwork
Postby Killiestu » Sat Dec 08, 2018 12:48 pm
Old post but anybody know how thick the hub adapters were on the rear? Is the front hub re-drill straight forward enough?
Sent from my SM-G950F using Tapatalk
Killiestu
Postby Perfectpaintwork » Mon Dec 17, 2018 12:34 am
10mm rear hub adaptors
Just buy new set of front hubs and drill them
Perfectpaintwork
Postby Killiestu » Mon Dec 17, 2018 7:05 am
Thanks for the reply.
10mm !!! Is that even safe? Seems very thin , I've never used a hub adapter so I might be getting it wrong
Killiestu
Postby Shaun306 » Fri Dec 21, 2018 9:30 pm
Did you ever complete one in Australia ?
Shaun306
Postby ossie cossie » Sun May 10, 2020 3:42 pm
nice van
ossie cossie
Users browsing this forum: Bing [Bot], Majestic-12 [Bot]
