Mk2 Transit 190 LWB
Re: Mk2 Transit 190 LWB
Postby MinorMatt » Mon Sep 08, 2014 11:13 am
Thats a '95 or earlier pump
The solenoid on the side is for advancing the timing for cold starts.
It will work fine, but you may not be able to advance it enough on the slots (meaning you need to pull the boss off, rotate it a bit and put it back).
Postby PIO » Mon Sep 08, 2014 1:50 pm
Cheers Guys,
Haven't bought that pump yet, just wondeirng am i better off waiting for a later type pump so.
Anybody have one for sale ?
PIO
Postby PIO » Mon Mar 16, 2015 8:29 pm
Smallest of updates...
Finally picked up my donor 1996 chassis cab and thankfully it has a 100Ps engine with only 47K, also has a wide ratio MT75. It was parked outside all its life on wet grass and just rotted through....Hence the low mileage and early 'end'...Picked up a Bosch 145 Pump from a 2000 van...
Put a fresh battery in it and fired up straight away, it goes well...
The chassis cab has a 5.14 rear axle, not sure would I be better off going for a 4.63 Diff.
Would like the 4.63 diff for cruising, but also want the ability to tow the Capri....
PIO
Postby Kedishen » Thu Mar 19, 2015 5:07 pm
working epic and ecu will come in handy for others on here. always smebody wanting one.
Livin' in me van in Portugal.
'93 Mk4 TD 150L Hitop Custom Camper
100ps Epic blue spot
Kedishen
Postby MinorMatt » Fri Mar 20, 2015 8:09 am
That should be a dsa1096 pump. If the price was right I would buy it as a spare for my van. I haven't heard of a faulty ECU.
Postby PIO » Sun Mar 22, 2015 12:52 am
Minormatt, would be delighted to help you out....
Should get at this in the next few weeks, will keep you posted...
The price will be right as I have no idea what its worth ha ha...
PIO
Postby MinorMatt » Sun Mar 22, 2015 10:53 am
:lol:
Im not out to rip anyone off... the last epic pump I bought was £40 (1st bid on ebay) I've been given them before as well... BUT I have seen them go for over 200 on ebay too :shock:
Postby Kedishen » Sun Mar 22, 2015 5:37 pm
£200 :o one of those dealer specials surely??? Last one on the planet perhaps... I suppose compared to the price of a bosch pump + bits + time to find all the gubbins + the mechanic to fit.. that kinda price can be justified I suppose... Personally I would be spending the money on the bosch pump etc and not having the worry of does the accelerator decide not to function one day...
Kedishen
Postby PIO » Sun Mar 22, 2015 9:58 pm
Minormatt... I have two of them, todays your lucky day ha ha...
I presume I'm only dreaming to think that I could find a LSD for my Mk5 twin wheel axle.... Also on the look out for a 4.63 crown wheel & Pinion.
PIO
Postby MinorMatt » Mon Mar 23, 2015 5:39 pm
LSDs are out there... but not common
I have one sat on my shelf which was on my last van - I just haven't transferred it to the current one yet
Postby PIO » Sat Mar 28, 2015 10:13 am
Morning Minor Matt... Fancy doing a deal on two pumps plus cash for the LSD... Can't blame a man for asking anyway
PIO
Postby MinorMatt » Sat Mar 28, 2015 11:32 am
No thanks... I need the LSD to help me get out of muddy fields...
Once I have got it back its one of the 1st things to be swapped/re-fitted from my old van
Postby PIO » Sat May 30, 2015 8:38 pm
Haven't had any time to get at my van, been busy getting my Capri's ready for summer.
Anyway, got myself a Bosch '145' pump
Picked up a Mk5 Axle from a 115Ps Ambulance, was hoping for an LSD but no Joy... It has a 4.63 Ratio though...
Also picked up the Intercooler/pipe work and radiator while I was at it...
Must just find the time to get some work done on it now...
PIO
Postby PIO » Mon Jun 08, 2015 10:51 pm
Had a quick route around my donor tonight...
Getting a few pics for MinorMatt
P/s Kick Panel
[IMG]
http://i68.photobucket.com/albums/i33/m ... xy0w2h.jpg[/IMG]
D/S Kick Panel
Not sure what this switch is for...
PIO
Postby PIO » Sun Jun 21, 2015 10:10 pm
Got some time to get at my donor today...
Some pics below for Minor Matt
PIO
