DMF conversion. Urgent advice please.
Postby fabfor » Mon Jun 08, 2015 6:49 am
Mk6.2002.2.4.350.rwd
Mine broke down while driving on Friday - couldn't put it into gear after stalling. My mechanic says the clutch is Ok but DMF needs replacing (bearing balls fell out). He recommends conversion to SMF and I'm planning to buy (collect) a kit off eBay today for £129.
KIT CONTAINS THE FOLLOWING:SINGLE MASS FLYWHEEL, CLUTCH PRESSURE PLATE, CLUTCH DRIVEN PLATE, CLUTCH RELEASE BEARING, CLUTCH RELEASE FORK, AND FLYWHEEL RETAINING BOLTS.
I'm happy to go ahead with the conversion but are there any other things we should check? Any advice would be greatly appreciated. Thanks.
fabfor
Re: DMF conversion. Urgent advice please.
Postby Mr RVM » Mon Jun 08, 2015 11:28 am
fabfor wrote:Mk6.2002.2.4.350.rwd
I would fit a new spigot bearing while your on (bit of a bugger to do) Most of those that complain of vibration after converting to single mass flywheel have usually forgotten or not bothered to change this :wink:
Mr RVM
Postby fabfor » Mon Jun 08, 2015 12:13 pm
Thanks for that, Mr. RVM. :-)
fabfor
Postby fabfor » Wed Jun 10, 2015 11:19 am
The conversion was done yesterday using the Valeo kit from Eurocarparts (£220). Van feels fine but gear changing is just slightly less smooth.
Mysteriously, we found ball bearing debris in the bell housing and can only assume that it came from a previous starter motor ..?
I'd started driving the van after returning from a 4 month trip 3 weeks ago and noticed a squeal coming from the fan belt. The squeal's still there after the conversion and I'm wondering if it's related to the advice on the forum to change the crankshaft pulley. Squirting soapy water on any part of the belt or pulleys get rid of the squeal but only for a few minutes.
For the record, my mechanic rates the Valeo kit as good quality.
fabfor
Postby APH » Wed Jun 10, 2015 5:16 pm
Never had a crank pulley fail on a mk6, there metal not rubber like the mk7, try a new belt first, may be all it needs, while its off check the smoothness of the idler pulley and tensioner pulley (the two little black ones that don't have groves in them for the belt) when you spin them, if either feel rough, or rumble, or wobble from side to side if you wiggle them, change those too. Very common failing on the Mk6.
Andy :D
(\__/)
(")_(")
this is bunny
APH
Postby fabfor » Thu Jun 11, 2015 12:14 pm
Very useful. Thanks Aph.
fabfor
Postby karl » Thu Jun 11, 2015 2:30 pm
but all in all what is your experience with the conversion
ive just done mine no rattles,no pieces of steel grinding together nice and smooth and noticing more miles to the gallon :D
karl
Tranny Lover!!!
Postby fabfor » Sat Jun 20, 2015 4:48 am
Changing the belt got rid of the squeal. All in all, i'm happy with the conversion. The van drives well and no built in DMF problem to worry about. I'd put reliability above a little smoothness every time.
fabfor
Postby transit mark » Sat Jun 20, 2015 8:32 pm
I just done a solid conversion on mine, also changed the spigot bearing. All seems ok at the moment. I only paid £400 for the van. Picture below.
2001 MK6 90PS MWB RWD
transit mark
Users browsing this forum: gt_addict, metalworker0
