mk7 power loss
mk7 power loss
Postby dredge3 » Mon Jun 08, 2015 3:37 pm
Hi. I have a 2011 mk7 2.2 fwd t300 transit. Last year under warranty, I had loads done. Injectors, valve at end of rail. This was for pulsing tickover. Stopped pulsing, yet less MPG? At the time of all the work going off (8 months)at one point I had a power loss going up hills. This stopped.
2 days ago it was windy and It felt like power loss, 30 seconds later, again power loss. I was thinking could be the wind.
Today, SAME PLACE! power loss. Its a 60mph straight, left bend, small incline. Don't know if its anything to do with it, but odd its in the same place
dredge3
Re: mk7 power loss
Postby dredge3 » Tue Jun 09, 2015 10:23 pm
Today. same place, same thing. Very odd as its only on that road. Drove 30 miles without a problem. Tank is 3/4 full, so not a problem on that side
dredge3
Re: mk7 power loss
Postby ake » Wed Jun 10, 2015 7:15 am
When was the fuel filter last changed?
Re: mk7 power loss
Postby dredge3 » Sat Jun 13, 2015 11:25 pm
ake wrote:When was the fuel filter last changed?
Not sure. I think |Ford changed it when they had the same problem along with other problems. That's about 6 months ago. The gauge says its fine. If they work.
So odd that it does it every time I go on this rd and no other. Sorry, did it on a very steep hill.It always under hard acceleration..I think.
il have to service it. See if it does anything
dredge3
Re: mk7 power loss
Postby dredge3 » Tue Jun 30, 2015 7:06 pm
Changed all filters. Still doing it.
Even slight misfire at tickover tonight..with aircon on.
This van has to last 5 years. Nearly 2 and its screwed
dredge3
Re: mk7 power loss
Postby loot » Tue Jun 30, 2015 11:09 pm
It'll be something stupid i bet.
07 350 170ps
Ids map here
loot
Re: mk7 power loss
Postby stevenw1963 » Wed Jul 01, 2015 11:52 am
Had something similar on my 59 plate MK7 140 ltd.
Turned out the turbo actuator arm was loose as there was no circlip holding it in place as there should be.
It only lost power when towing up a certain hill, found the problem when the actuator arm actually came off one day.
Arm now been held in place by a cable tie for last 2 yrs, problem solved.
May not be that but worth a look to see if the circlip is holding the actuator arm in place OK.
____________________________________________________________
The older I get, the better I was.
stevenw1963
Re: mk7 power loss
Postby dredge3 » Fri Jul 03, 2015 11:03 pm
Taking it to my friends garage. He does only Land Rovers but uses Snapon diag. Ill plug it in and see.
dredge3
