Ignition live
Ignition live
Postby transity2000 » Thu Jun 18, 2015 6:42 pm
got a set of drl need ignition live to get power.can I take power straight from the engine fuse box r3 with the live wire having a fuse . Or can I connect to the jumpstart point will that be ignition live or permanent live thanks guys
All i wanted was a trouble free transit
transity2000
Re: Ignition live
Postby ake » Thu Jun 18, 2015 8:44 pm
transity2000 wrote:got a set of drl need ignition live to get power.can I take power straight from the engine fuse box r3 with the live wire having a fuse . Or can I connect to the jumpstart point will that be ignition live or permanent live thanks guys
Jump start point is permanent live, but there's an ignition live in the fuse box beside it,
Look here :arrow: viewtopic.php?f=5&t=155512&p=1311819&hilit=Drl#p1311819
Re: Ignition live
Postby transity2000 » Thu Jun 18, 2015 9:10 pm
Thanks mate I read tht but just can't get my head around the relay and diode bit on wether I can take live direct out of it or will it need diode and relay
transity2000
Re: Ignition live
Postby Mike » Thu Jun 18, 2015 9:54 pm
transity2000 wrote: relay and diode bit
Where's that?
Mike
Wind up merchant!
Re: Ignition live
Postby transity2000 » Thu Jun 18, 2015 10:23 pm
transity2000
Re: Ignition live
Postby Mike » Thu Jun 18, 2015 10:57 pm
You mean the following quote where someone used my picture, claimed it as their own and talked shite? He's since gone a bit mad and disappeared ;)
limitedblack wrote:
Mike wrote:Image
That's my one in this picture, just use this to power a relay only, using the power from the side of this fuse box. It is rumoured that powering something direct from this point can cause malfunctions elsewhere. So I have a relay with the customary diode across it to stop it spiking back when de-energised.
Mike
Wind up merchant!
Re: Ignition live
Postby transity2000 » Thu Jun 18, 2015 11:16 pm
:lol:
transity2000
Re: Ignition live
Postby Mike » Fri Jun 19, 2015 7:31 am
Just to clarify, this is how the Ford dealer wired the MSDesign drl's when they fitted them to my 2010 van and I used the same feed when I fitted the Ledcom lights to my 2012 van, no diodes were needed.
Mike
Wind up merchant!
Re: Ignition live
Postby bigjohnthomas » Fri Jun 19, 2015 7:45 am
Shhhhhhhh he's watching :shock:
bigjohnthomas
