speedo issue
speedo issue
Postby maccavvy » Mon Jun 22, 2015 5:34 pm
Seem to have an issue with my speedo.
I take it its electronic.. long gone the days of speedo cables.
wheres the sender and if it is the clocks is it a simple swap over from 2nd hand ones.
what about the mileage etc etc?
in case of a dodgy wire which colour should I be testing.
thought id stack up on info before I tackle it .
Mk8 310 trend FWD and a 5.7 ls1 monaro RWD
maccavvy
Re: speedo issue
Postby ake » Mon Jun 22, 2015 5:43 pm
maccavvy wrote:Seem to have an issue with my speedo.
Speed signal is gained from abs sensors and fed to speedo using canbus circuit from ecus, there is no sender as such
If speedo is misbehaving, but everything else is ok, then it's most likely a cluster fault.
Mileage can be corrected using Ford ids. But you can only increase it, not decrease it
Re: speedo issue
Postby maccavvy » Mon Jun 22, 2015 6:38 pm
is there one cable as such sending a signal to cluster.
is mileage stored in the clocks if I don't have access to ids. will they fit and work just fitting them
maccavvy
Re: speedo issue
Postby ake » Mon Jun 22, 2015 9:20 pm
maccavvy wrote:is there one cable as such sending a signal to cluster.
No, not just one wire, it's a pair of wires, but they send signals for rev counter, gauges, lights etc etc
Mileage is stored in clocks, so new clocks will show different mileage
Re: speedo issue
Postby maccavvy » Mon Jun 29, 2015 8:23 am
if I fitted other clock would they need coding or just plug and play ???
maccavvy
Re: speedo issue
Postby knobby1 » Mon Jun 29, 2015 9:32 am
maccavvy wrote:if I fitted other clock would they need coding or just plug and play ???
Just curious with a Mk7 cluster...I know we can only "increase" the mileage via IDS, but what say we set it to a mile short of the maximum for the speedo, say 999,999 miles ....if we drive it for a mile, will it then tick over to zero??
Re: speedo issue
Postby ake » Tue Jun 30, 2015 7:13 am
It's been tried, and it just stays at 999,999.9 and won't click round!
Re: speedo issue
Postby knobby1 » Tue Jun 30, 2015 9:31 am
Fairynuff...no harm in asking..!
Re: speedo issue
Postby rustyman » Wed Jul 01, 2015 9:28 pm
just changed a 125 tdci engine with a 90 tdi only changed engine and gear box aswell as top half of loom which all matched up. but now I have no speedo but coil light and all other normal lights go out except service light. if anyone has any hints would be good cheers
rustyman
Re: speedo issue
Postby ake » Thu Jul 02, 2015 7:13 pm
rustyman wrote:just changed a 125 tdci engine with a 90 tdi only changed engine and gear box aswell as top half of loom which all matched up. but now I have no speedo but coil light and all other normal lights go out except service light. if anyone has any hints would be good cheers
Did one van have digital mileage read out and the other have analogue mileage?
