Non starting mk6
Non starting mk6
Postby dirtydog » Fri Jun 26, 2015 2:37 pm
Bought a 2003 90ps lwb hi top last week and all was fine for the first morning then it wouldn't start. Tried to jump start it but made no difference. Managed to get it started by pulling it down the road in 3rd so I figured it was the starter.
Put a new starter motor and battery on it this afternoon and still nothing.
With ignition off I'm getting 12.5 volts at the big cable at the starter until I turn the ignition on to where the lights come on the dash and then it drops down to about 5.5v. I get the same at the jump point under the bonnet.
Anyone got any ideas?
Starting to get grief from the other half for buying a lemon :(
dirtydog
Re: Non starting mk6
Postby dirtydog » Fri Jun 26, 2015 2:39 pm
Putting a multimeter on the battery I get a constant 12.5v ignition on and turning to start
dirtydog
Postby Altransit » Fri Jun 26, 2015 2:40 pm
Mine did this a couple of months back, the problem was that the glow plugs were robbing the power from the battery, eventually the link wire went up in smoke :shock: :roll:
I cut out the link wire and it's been fine since :D
Postby dirtydog » Fri Jun 26, 2015 2:41 pm
Where is the link wire?
Sorry for all the questions I'm a mk6 virgin :oops:
dirtydog
Postby Altransit » Fri Jun 26, 2015 2:44 pm
It's a fat wire coming away from the jump point. I don't know what colour it was, as it was burned to a crisp when I found the problem :mrgreen: :lol:
Postby Altransit » Fri Jun 26, 2015 2:45 pm
You could try pulling the glow plug relay and see if it starts normally :idea:
Postby dirtydog » Fri Jun 26, 2015 2:45 pm
Ok where is the relay?
Thanks for your help
dirtydog
Postby Altransit » Fri Jun 26, 2015 2:48 pm
Relay R2 Top left of engine fuse box, next to the jump point :wink:
:arrow: viewtopic.php?f=40&t=71739
Postby dirtydog » Fri Jun 26, 2015 2:54 pm
That's a handy link, thanks.
Pulled the relay, still no start :( Not even a click from the starter
dirtydog
Postby Altransit » Fri Jun 26, 2015 2:58 pm
OK, maybe you have a different problem to me, it did sound very familiar though :?
Postby Altransit » Fri Jun 26, 2015 3:00 pm
I've just re-read your original post, and I'm now wondering if you have a faulty ignition switch :idea:
Postby dirtydog » Fri Jun 26, 2015 3:21 pm
Just had my multimeter on the jump point again.
Ignition of 12.5 volts
Position 1 so radio comes on 12.5v
Position 2 dash lights on 5.5v
Turned as if to start voltage drops to 0.2
dirtydog
Postby Mr RVM » Fri Jun 26, 2015 3:31 pm
Altransit wrote:I've just re-read your original post, and I'm now wondering if you have a faulty ignition switch :idea:
And I would go with that :!:
Mr RVM
Postby dirtydog » Fri Jun 26, 2015 3:52 pm
As in the bit attached to the end of the ignition barrel?
Am I pushing my luck hoping that the mk6 and mk5 have the same ignition switch
dirtydog
Postby bambi mk 1 » Fri Jun 26, 2015 4:08 pm
A mk 6 will never ever be the same as a mk 5 :wink: No they wont fit but a mk 7 will .
bambi mk 1
Users browsing this forum: knobby1, metalworker0
