Transit 2.5 Turbo Diesel diagnose plug
Postby sven98de » Tue Aug 23, 2011 3:22 pm
Hi,
I have a Transit 2.5 Turbo Diesel camper build 1993 and I'm looking for information about it's diagnose plug.
The only connector I found in the engine compartment was that:
Is that the right one ? As far as I can see there are three pins, does anybody know the connector pin assignment ? What protocol is used for the data transfer, is it perhaps a simple serial protocol, which could be read by a simple serial interface and a terminal program ?
cheers
Sven
sven98de
Re: Transit 2.5 Turbo Diesel diagnose plug
Postby MinorMatt » Tue Aug 23, 2011 3:32 pm
that does look like a diagnostic plug - my mk5 has one there and as far as I have been able to work out its for ABS. I thought the mk4 socket was in/around the glovebox area?
If you PM Frag he will tell you how to read the codes using a paperclip! (this does not work for Mk5 turbos before anyone asks...)
Postby sven98de » Tue Aug 23, 2011 4:41 pm
Do you mean these plugs, which are located under the glove box ?
What are they for ?
sven98de
Postby MinorMatt » Tue Aug 23, 2011 5:03 pm
I think they are the engine diagnostics
Postby MrMPuk » Tue Aug 23, 2011 5:07 pm
That's the ones.
Postby V184 » Tue Aug 23, 2011 6:11 pm
The 2 pin is for the Ford fds2000 tester you used to have to fit a inline adapter, the 3 pin was for a star tester cant remember which one the Lucas tester used
V184
Postby ake » Tue Aug 23, 2011 7:36 pm
Sure lucas uses 3 pin
Postby martynx » Mon Jun 29, 2015 1:48 pm
Anyone know the pinouts & whether IDS can work on these or its just FDS or Lucas 2000 ? its for Robbies BOA/BOB Cosworthed MK3 & it uses a 3 pin connector which I assume is like the one on these vans ! ?
martynx
Postby MinorMatt » Mon Jun 29, 2015 1:51 pm
I can't imagine that IDS would work.
I have laser 2000 and a sykes pickavant code reader which should both work on robbies van...
Postby martynx » Mon Jun 29, 2015 1:53 pm
MinorMatt wrote:I can't imagine that IDS would work.
Cool :) You are at North Weald next week aren't You ?
martynx
Postby MinorMatt » Mon Jun 29, 2015 1:56 pm
Yup
Laser is in the back of the van, and sykes is down with the other one
Postby martynx » Mon Jun 29, 2015 1:56 pm
Ace :-)
martynx
Postby Altransit » Mon Jun 29, 2015 5:20 pm
martynx wrote:Ace :-)
Don't forget that Andy has a Laser 2000, (and an FDS2000!) if you can't meet up with Matt :wink:
Postby martynx » Mon Jun 29, 2015 7:30 pm
Cool , options ;) Robbies after some live data I think.
martynx
Postby robbie.cee » Mon Jun 29, 2015 8:39 pm
Yeah And btw my 'diag port' is a 16amp industrial iec connector cos I had no socket and had lots of said plugs and sockets to match! Kept orig plug on code reader, happy to extend wires etc as its only earth and 2 data wires... but....
queation is, forgwt the 60pin ecu plug which has diag wires in... why is there a cover on REAR of ecu that has some sort of pcb connector bit like a pci card fpr a pc but Smaller!?
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
