EGR P0490 fault code
Postby Petters » Mon Jun 29, 2015 3:36 pm
I have a EGR P0490 fault code, its been there as long as I had my car, but now I have to do something with it to get away the enegine light because of new rules on the euro control we have in norway every second year.
I can delete the fault code, and it can be away for 5 minutes or to i stop and start the enegine again.
I have taken of the eletric part of the EGR and checked it, its not stuck and the eletrick part works when I put 12volts on it.
Nothing happens when I put on the Ignition, no clicking in the eletric part.
Sombody now if there is some sensors adjusting the eletric part ?
Sorry for my bad english, I´m Norwegian :)
Ford Transit Connect 1.8 TDCI 2007
Petters
Re: EGR P0490 fault code
Postby paul2012 » Mon Jun 29, 2015 4:58 pm
Over here in the UK. We have very similar rules due to be added to MOT tests in 2017 :(
P0490 EXHAUST GAS RECIRCULATION (EGR) "A" CONTROL CIRCUIT HIGH
First check to make sure EGR valve itself is not seized.
This vid here maybe of help :arrow: https://www.youtube.com/watch?v=UwsyFzg_OGM
EGR valve itself should be free moving :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Petters » Mon Jun 29, 2015 5:12 pm
This rule came this month in Norway, with a lot of others... :(
But the valve is free!
When I had the motor off, I did screw it apart and i tested it with a 12volt charger, and the motor works fine on this. But the motor is not clicking when I turn on the ignition..
I have read a lot of threads on the forum, but cant find any good answer to this problem.. :(
Petters
Postby Petters » Tue Jun 30, 2015 7:33 pm
No idea what this can be ? A college of me have the same fault code on his connect, dont know if its coming back after its deleted, that I will find out tomorrow. :)
It drives me crazy that I cant figure out what this sh*t is.
Petters
Postby gt_addict » Tue Jun 30, 2015 7:52 pm
Wouldn't be a faulty relay would it? If the motor and actual valve are fine.
gt_addict
Postby Petters » Thu Jul 02, 2015 3:31 pm
I dont know if there is any relay or a sensor controlling the system, but if there is it look like it can be someting like that.
Petters
Postby paul2012 » Thu Jul 02, 2015 5:43 pm
There is no relay for EGR valve on Euro 4 engines.
Motor may work when bench tested. Although there is a EGR position sensor within in the back end cap.
If wiring & plug is ok. Only solution is to replace assembly. Unfortunately EGR motors are not supplied separately from Ford. You have to buy complete inlet manifold :(
paul2012
Postby martynx » Wed Feb 15, 2017 2:08 pm
Post Brexit, are the 2017 MOT regs being implemented as originally planned regarding functional EGR's :?:
They can be switched of on Connects these days ( a solution wasn't available for years ;) )
http://vantuner.co.uk/ford-connect-euro-1-8-tdci-2006-onwards-egr-delete/
for egr/dpf deletes, power tuning, updates,cloning,speed limiter removal,cruise control, euro 3/4/5/6 limiters & key's !
martynx
Postby paul2012 » Wed Feb 15, 2017 8:00 pm
martynx wrote:Post Brexit, are the 2017 MOT regs being implemented as originally planned regarding functional EGR's :?:
Unfortunately yes they are still being implemented.
It's worth noting, even after Brexit. Future EU directives will still apply to manufacturers based here in the UK.
For example vehicle manufacturers. If vehicle / engines (Like Transit engine built here in the UK). Don't meet EU standards, they can't be exported. :roll:
paul2012
Postby darkbluevanman » Wed Feb 15, 2017 11:05 pm
paul2012 wrote:There is no relay for EGR valve on Euro 4 engines.
Plus testing with a charger isn't the best.. (unless it's a norsk/eng conv) chergers are unregulated and voltage are wild!
darkbluevanman
Postby M@tt17 » Wed Apr 26, 2017 9:04 pm
If the valve is free I don't need to change the manifold?
M@tt17
Postby kjb » Wed Apr 26, 2017 9:58 pm
I recently had this very fault on an 09 tdci, luckily i had a donor egr valve from the sister vehicle, i swapped both valves from vehicle to vehicle so as i could rule out the valve, turned out to be the manifold, expensive solution unfortunately
kjb
Postby tez » Thu Apr 27, 2017 1:00 am
r map and delite it from the ecu job done no trouble again
tez
Postby M@tt17 » Fri Apr 28, 2017 5:45 pm
Can anyone recommend a remap guy in the north west cheers
M@tt17
