Baz has a new home!
Re: Baz has a new home!
Postby dieselhead123 » Thu May 07, 2015 9:08 pm
Found another pic of the front crossmember, now in primer;
When there is BLUE paint in the gun it will get some :wink:
Postby ColinJack » Thu May 07, 2015 9:36 pm
That front end is a work of art Tim!
Well done. Did you get the PDF for the MOT man?
1989 Mk3 Reimo Camper
1980 Mk2 Holdsworth Camper
ColinJack
Postby dieselhead123 » Fri May 08, 2015 9:13 am
ColinJack wrote:That front end is a work of art Tim!
Thanks Colin 8)
Got the PDF, I will show it to our testers next time I am in there.
Postby transitandy » Fri May 08, 2015 8:31 pm
Great work as ususal tim :)
Postby ColinJack » Sat May 16, 2015 12:01 pm
Thanks Colin 8)
Let me know when you want the seats! :wink:
ColinJack
Postby RustWidow » Sat May 16, 2015 1:16 pm
Such a good job Tim, well done mate
RustWidow
Postby transitandy » Sat May 16, 2015 1:32 pm
RustWidow wrote:Such a good job Tim, well done mate
Thats why I chose Tim to do my van :D 8)
Postby RustWidow » Sat May 16, 2015 2:16 pm
Yep, that makes sense
RustWidow
Postby ColinJack » Sat May 16, 2015 3:03 pm
Me too. He has done quite a bit on my vans and well worth going all the way down to Kent to get someone I know I can trust to do a good job at a fair price (because my welding is shite! :lol: ) and who has an encyclopaedic knowledge of Ford Transits!
ColinJack
Postby dieselhead123 » Mon Jun 29, 2015 6:59 pm
Been getting on with bits on Baz, although we have had the front panel offered up, it can't go on until we sort out the tops of the headlamp panels.
The right hand side is worse;
A replacement part had to be made for this, we started with a card template which was then transfered to steel and the part cut and shaped;
Because of the shape of this part it was necessary to produce it in sections and weld it together. The parts were clamped to the existing panel and tacked together. Welding and final shaping produced this;
Next the rusty part was removed ready to fit our new part, the upper part of the headlamp panel it fixes to is also in a poor condition. A replacement will need to be made for this;
Postby ColinJack » Mon Jun 29, 2015 7:13 pm
dieselhead123 wrote:Been getting on with bits on Baz, although we have had the front panel offered up, it can't go on until we sort out the tops of the headlamp panels.
Wow - you are quite good at this aren't you? :lol:
That really is looking good Tim - brilliant work. I need to pop down and see you with an envelope some time! Can bring the seats down too.
ColinJack
Postby dieselhead123 » Mon Jun 29, 2015 7:37 pm
Just let me know when Colin and I'll put the kettle on :D
Another member on here has a replacement bonnet, (the one on Bax is a bit sad), he would like to 'trade' it for a few new panels. Be good to get a better one as bits of it keep falling on my head :shock:
What seats have you got?
Postby ColinJack » Mon Jun 29, 2015 8:32 pm
dieselhead123 wrote:Just let me know when Colin and I'll put the kettle on :D
Have to see what we can do - diary a bit crazy at the moment. Taking the Mk3 down to Malaga again end of next week (via France & Spain). Seats were posted earlier on the thread:
viewtopic.php?f=27&t=147648&start=165#p1341881
PM me on the bonnet - need to keep an eye on budget!
All the best - looking good.
Colin
ColinJack
Postby dieselhead123 » Wed Jul 08, 2015 7:16 pm
Today the upper part of the right hand headlamp panel was replaced, not only was it necessary to replace the top but the vertical part by the radiator was also in poor condition. We started with this part;
We then replaced the top part;
Captive nuts were welded to the underside of the panel to accept the front panel fixings, then the upper part was spot welded to the new headlamp panel top and seam welded at the 'join';
Paint tomorrow :D
Sorry for the very poor pictures chaps :oops:
Postby ColinJack » Wed Jul 08, 2015 7:30 pm
dieselhead123 wrote:Today the upper part of the right hand headlamp panel was replaced, not only was it necessary to replace the top but the vertical part by the radiator was also in poor condition. We started with this part;
Paint tomorrow :D
That is coming on a treat. Will pop down when we get back from Spain. Colin
ColinJack
