My trusty but rusty MK6 fwd
Postby edz27 » Sat Jul 11, 2015 5:40 pm
So here's a few pics of my mk6 6 the first transit I've ever owned, it must of had a hard 15 yrs with no care considered at all and then just px'd when it was on its last legs, although the engine seems spot and starts first time I've had a few initial electrical probs to sort along with the clutch master cylinder to change, the biggest problem tho is the amount of rot underneath now im no stranger to a angle grinder and welder so im hoping ive not bitten of more than I can weld here a pic of the van and what ive done so far
Now this bit was a shock
plans just keep it road worthy for now then who knows
edz27
Re: My trusty but rusty MK6 fwd
Postby Altransit » Sun Jul 12, 2015 3:31 pm
edz27 wrote:Now this bit was a shock
That's one of the normal rust areas on these, sadly :(
Nice neat job on the wheel arches 8) :D
Postby edz27 » Sun Jul 12, 2015 9:39 pm
As well as all the welding at the rear I also need to do the inner front sills, now ive seen this part for sale but don't think I need the section that goes up into what I presume is behind the wheel arch can I cut the up right section off and use whats left to repair the inner sill or is there another repair section available?
edz27
Postby Cal1990 » Wed Jul 15, 2015 8:26 pm
Ul have to chop it off mate and just patch it into good metal
mk7 Transit swb low roof in beautiful black :)
Cal1990
Postby edz27 » Thu Jul 16, 2015 11:08 pm
Got a few more bits done found a local supplier 5 mins from me a little bit dearer but no postage https://www.crashrepairparts.com/session/login
probably done wrong part first but hay ho it'll look the same when done hardest part is finding fresh metal to weld to,
edz27
Postby edz27 » Thu Jul 30, 2015 7:06 pm
Ended up cutting the wheel arches of as I wasn't happy trying to fit the inner arch with the arch in place, I had to weld it back together as I had cut it to try and make it fit
And then onto the other side
And the left over bits
edz27
Postby davew2 » Thu Jul 30, 2015 7:16 pm
Cracking job there mate :D
If it ain't got leaf springs it in't a commercial
davew2
Postby RustWidow » Thu Jul 30, 2015 10:08 pm
Wow, epic job, well done
RustWidow
Postby Altransit » Fri Jul 31, 2015 11:19 am
Nicely done 8)
The inner wings looked OK on your van, mine were rotten :shock: :mrgreen:
Postby walt1984 » Fri Jul 31, 2015 11:32 am
I cant beleave there is no paint or anything inside the sills etc.
No wonder they rot.
I really need to blather mine with wax old. Been gunna do it since it was new and its nearly 4 yrold now.
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Wax oil. Bloody predictive txt.
walt1984
