Supervan
Supervan
Postby Aussievanner » Fri Apr 20, 2007 7:58 am
People have probably put this up 1000 times, but I'm going to put it up again. I do have a reason though
Other than the fact that it's frikin cool, I want to know if anyone knows how to go about lowering one like that. I can lower the rear simply by using lowering blocks, but the front has the leaf springs going over the mock axle, is there a way of refitting so that the springs go under it therefore lowering the front at least 2" or is there some kind of conversion kit available.
Please help, it looks awesome that low.
Secondly, I want the same headlight surrounds, I have the old round headlight setup, with the full length indicators and the unremovable grill, is it possible to change it to that setup.
Aussievanner
Postby MrMPuk » Fri Apr 20, 2007 10:31 am
That's low because it's a fibreglass body on a car chassis!
Postby FredTransit » Fri Apr 20, 2007 10:38 am
Lowering aside, the headlights are Mk2 phase2. To fit them you need the panel the rad is bolted to (second hand only now, they were never offered as a pattern panel.) a plastic grille and the headlights. The headlights fit to the radiator/grille mounting panel via the adjusters, which may or may not come with the panel. Do the 'wrap around' indicators too, ans the phase1 smaller indicators don't look right with the plasic grille.
FredTransit
Mk2 Trannyist
Postby Luke » Fri Apr 20, 2007 12:11 pm
you cant lower the rears easly - lowering blocks become raising blocks - on the rear! you can either bend the springs or if you wanted to go radically low then mabe mounting the rear the other side of the leafsprings is possable! :?
the front will need some thinking about regarding the steering box linkages! - ive lowered mine by fitting mk4 ifs and cutting the springs down - depends how much work your prepaired to take on! :)
and mk2 phase 1 is soooooooooooooo much neater than the phase 2 keep the one you have :lol:
Postby FredTransit » Fri Apr 20, 2007 12:22 pm
Luke wrote:and mk2 phase 1 is soooooooooooooo much neater than the phase 2 keep the one you have :lol:
Actually I nearly said keep the front end you have, they are much rarer despite there being more made than the phase2.
FredTransit
Mk2 Trannyist
Postby Granadadriver » Fri Apr 20, 2007 9:30 pm
In case of the Supervan lowering looks: Maybe channeling is the way to go! :D Don't know if it's possible to do this work on a Transit panel van? :? It's very extensive work for sure! (if it's possible!)
Granadadriver
Postby Sundowner » Fri Apr 20, 2007 11:53 pm
You can have the springs reset
Im sure theres a place in Vic that can do it i know K-mac do it
and theres no way you will get it that low using the factory setup not even if you C notch the chassis
Yeah i know its big green and rusty so move your Porsche before i bash it with 460 cubes of fords finest cast iron
Sundowner
Postby carnut1100 » Thu Jun 14, 2007 5:50 am
I want to replicate that van with a spaceframe chassis and a mid mounted Boss 260 :D
1979 Mk2 Truck Project thread here
carnut1100
Postby bigmastif » Fri Jun 15, 2007 7:54 pm
why not maybe think of useing hydrualics to lower the van like cat daddys van :idea: that way needs be you can lift it up to get over kerbs and such :wink:
bigmastif
low transit
Postby blue meanie » Sat Jun 16, 2007 3:46 pm
g'day mate just a thaught.have you concidered dropping your body on to a holden 1 tonner chassis?.have seen it done to an old ford truck shell with top results.but will still require heaps of work i cant think of a better way to make a holden usefull
I'D RATHER PUSH MY TRANSIT THAN DRIVE A BEDFORD
blue meanie
Postby carnut1100 » Mon Jun 18, 2007 3:53 am
That'salways a good trick. There's a nice looking rat rod not far from my place with a '30s Chev body on a Holden chassis with Valiant running gear. Sits lower and goes far harder than the original!
carnut1100
