Positive camber
Positive camber
Postby roperman » Wed Jul 15, 2015 8:23 pm
Hi,
i've got a mk6 XLWB minibus that has positive camber on the n/s front wheel. It was in a smash before I bought it on the o/s and has had a new strut etc on that side.
Its about 2 degrees positive according to ATS (just about discernible if you look carefully)
I have replaced the lower wishbone on that side, to no avail. I'm thinking its either the subframe is bent, or the hub or strut. Just had a new wheel bearing put in the hub too :s. Camber is fine on the other side, which to me would be the first side of the subframe to bend, so I'm thinking thats escaped damage. I'm leaning towards the hub more than strut, unless anyone has a better idea.
Is there anywhere I can get accident repair measurements so I can replace the right bit(s) rather than doing it piece by piece.
Thanks,
Danny
roperman
Re: Positive camber
Postby knobby1 » Wed Jul 15, 2015 11:23 pm
Hi Danny,
Some "wheel alignment" places can fit a "camber bolt" to the inner/lower wishbone mounts, it has an eccentric shaft and allows a small amount of camber adjustment, might be worth asking at your local alignment place.
Failing that, you may indeed have a "bent" something, have you had a good look underneath to see if there's anything obvious??
