Max possible bhp from 2.4 tddi
Postby rob hall » Mon Jul 20, 2015 2:12 pm
I was on u tube and i saw a skoda (120 bhp) diesel producing 260 bhp on the rollers, it had been remaped and had lpg and nos kit fitted ,so would what bhp would be possible from a transit 2.4 90bhp tddi ??
the welsh A-team!
rob hall
Re: Max possible bhp from 2.4 tddi
Postby MinorMatt » Mon Jul 20, 2015 2:18 pm
It depends how far you want to go, how long you want it to last, how big a turbo (lag) you want and... HOW MUCH MONEY YOU HAVE!
Postby TIMO » Mon Jul 20, 2015 2:27 pm
dunno if a duratork block will handle much more than 200,,, mine shat a conrod the other day and was only mapped from 90 to 125.
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Postby rob hall » Tue Jul 21, 2015 10:35 pm
Nitrovan was running over 200bhp so the same bhp should be possible out of a 2.4 ?
the welsh A-team!
rob hall
Postby TIMO » Tue Jul 21, 2015 10:37 pm
rob hall wrote:Nitrovan was running over 200bhp so the same bhp should be possible out of a 2.4 ?
i doubt that it had standard conrods and pistons though buddy
TIMO
Postby bigyellow » Wed Aug 12, 2015 10:26 am
speaking to someone about this yesterday he reckoned the engine could go 250 but after that its not worth it, to do that power y0u are looking at new pistons , cranks and rods and so forth but after beefing up every thing the side of the block becomes the next weakness so its not worth it
i was told if i wanted to get more horses to look in another field and try larger engines with more room to increase the power levels rather than flogging a dead horse
we were speaking of lifting the engine i have to one of the regulated higher power levels for the van but we are still uncertain.
the next problem is after 300+ horses its the drive train that will fail to work correctly
bigyellow
Postby rob hall » Wed Aug 12, 2015 8:40 pm
Do u think 160-200 bhp would be possible by add nos ?
the welsh A-team!
rob hall
Postby andypdq » Wed Aug 12, 2015 9:49 pm
If you want seriously big power then a bigger engine is the way to go, Trying to get silly power from a small engine is an expensive business, everything is highly stressed, so reliability and longevity will suffer if you use it to the full. A big relatively understressed engine will perform and last, and will be cheaper in the long run, there's no replacement for displacement. :D
The first Mk 6 mechanical TDDI, giving electronics the finger, since April 2013
Perfection is reached, not when there's nothing left to add, but when there's nothing left to remove.
YouTube https://www.youtube.com/channel/UCNypVH ... dKUN5eJDyQ
andypdq
Transit 2.4 TDCi POWER UPGRADE
Postby goldcoast » Fri Jan 01, 2016 12:35 am
Here in Australia the common POWER UPGRADE for a MK7 2.4 TDCI is:
Replace it with the 200hp 3.2L Duratorq with Automatic transmission from a Ford Ranger Pick UP/Utility
The 3.2 TDCi Durotorq is standard fitment to US Ford Transits anyway so it is a good and easy fit!
Note: The US engine is downgraded for emissions from Aussie 200 hp to US 185 hp
I will probably put one in my Mk5 when the Auto trans or Lucas injector pump die.
2000 Mk 5 RWD 2.5 TDI LWB Manual 5 High Roof White
1997 Mk 5 RWD 2.5 TDI LWB Automatic Mid Roof White
+ previously 2008 Mk7 LWB T350 6 speed High Roof
:lol:
goldcoast
Postby 4x4 tranny » Mon Jan 25, 2016 7:26 am
Hi
yes have thought of that but do you know someone who's done it?
Be very interested in talking to them if so.
4x4 tranny
Postby PAULDRIVER » Wed Feb 03, 2016 11:22 am
Not seen a 3.2 duratorq, is there any in the uk ?
PAULDRIVER
Postby blue estate » Wed Feb 03, 2016 1:00 pm
Loads what do you thinks in the 200 ps transit
blue estate
