140 rwd annoying abs light and carnt seem to find fault
Postby haze » Mon Jul 20, 2015 7:47 pm
Hi all im back again i have the orange circle light on dash below handbrake light i have new discs and pads all round i have just serviced it aswell its a 140 mk7 rwd 08 this light driving me mental am i right in thinking its abs related ive checked common wire over rear axle also had a multi meter on abs sensors and all seem to be throwing back same reading apart from rear passenger side showing higher ..!! Ive also checked and cleaned abs rings front and rear and rear diff oil ok anyone got any ideas on anything i could of missed out on ? Please the lights driving me mad it obly seems to come after like two mins of moving of or starting or leaving ignition on for that time also pops up ive also pulled battery under seat to see ive i could reset it that way ..
T350 LWB 2.2 RWD 125 BHP
In silver with Air con and custom limited alloys
Is the lattest addition..previous transits I've had
R427 GBM reg 150 swb turbo smiley in yellow what a van 16 inch wheels rwd twin side loading doors and was rapid...
:D
haze
Re: 140 rwd annoying abs light and carnt seem to find fault
Postby TIMO » Mon Jul 20, 2015 8:03 pm
haze wrote:Hi all im back again i have the orange circle light on dash below handbrake light i have new discs and pads all round i have just serviced it aswell its a 140 mk7 rwd 08 this light driving me mental am i right in thinking its abs related ive checked common wire over rear axle also had a multi meter on abs sensors and all seem to be throwing back same reading apart from rear passenger side showing higher ..!! Ive also checked and cleaned abs rings front and rear and rear diff oil ok anyone got any ideas on anything i could of missed out on ? Please the lights driving me mad it obly seems to come after like two mins of moving of or starting or leaving ignition on for that time also pops up ive also pulled battery under seat to see ive i could reset it that way ..
try fuses 13 20 and 21 and related relays mate viewtopic.php?f=40&t=49206&p=793759&hilit=fuse+locations+mk7#p793759
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Postby ake » Mon Jul 20, 2015 8:06 pm
That's the pad warning light not the abs light, so it's not an abs fault
The abs light is on the Rev counter
There's must be a broken wire somewhere in the circuit. Were the wear sensors replaced with the pads? Disconnecting battery won't reset it.
Postby haze » Mon Jul 20, 2015 8:45 pm
I wasnt sure which warning light it was 100 percent it did come on now u come to mention it before the front pads hit the discs and i have now replaced discs and pads and new sensors maybe i need to check front pad connections ill have a look tomra when im back in my scruffs and see thanks so much for youre replies ill also check all fuses aswell while im at it because rear light clusters were faulty and did blow a couple but replaced them aswell now hopefully i can get to the bottom of it easily
:D
haze
Postby knobby1 » Mon Jul 20, 2015 9:19 pm
Had same issue with mine when I replaced the pads & disks.....one of the wires from a wear sensor was pushed out of the loom connector when I fitted it, open circuit means light on the dash....had me scratching my melon of a couple of hours.... :wink:
Users browsing this forum: Google Adsense [Bot], knobby1, metalworker0
