My mk5 smiley V6 Jag engined van
Re: My mk5 smiley V6 Jag engined van
Postby conrod » Thu Jul 23, 2015 8:48 am
My daily is a Mondeo ST220 which has basically the same engine - it's a mega engine too! I think the Jag has a different valvetrain than the Mondeo, and variable cams. All aluminium and a very compact unit. What trans are you going to run behind it? Manual or auto?
conrod
Postby robbie.cee » Thu Jul 23, 2015 8:58 am
Looks like i better get a superchip then
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Thu Jul 23, 2015 9:04 am
Pocketrocket wrote:
robbie.cee wrote:Wow! Bookmarking this one!
Well Its partially your fault why ive got 1 robbie!
Seen your green un at north weld and liked the look of it and the inside too, fast but still a usable van :wink:
Cheers might even be properly running soon !
Get it done before next weald matey !!!
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Thu Jul 23, 2015 9:07 am
Ps if poss use jag diff or get a lsd for your transit axle !
Pointless getting all that power just for one tire to smoke and not go anywhere, take it from me, its hard putting the power down, although The extra row of seats has defo reduced my tramping n spinning just need to get my.new diff and fit it....roll on transitmania!!
Had
MAKE IT FIT
robbie.cee
Postby MinorMatt » Thu Jul 23, 2015 10:10 am
My diesel either gets tramp or spins, one or the other!
Its one of the things to sort before next year, but I have some good ideas to be the 18s mark (still with standard turbo and 100ps injectors)
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby Pocketrocket » Thu Jul 23, 2015 1:16 pm
DodgeRover wrote:What fuel and ignition system are you going to be using having similar thoughts about putting one into my mk2
Ignition system/ecu/sensors etc all going to stay as standard, just going to remove the loom needed to run the engine and thats is it (will try and keep the cruise control if we can)
Traction control/abs/aircon etc basically all the non essential stuff will be getting binned :wink:
1999 mk5 tourneo (previously jagvan, now Vw PD powered)
2000 mk5 with a jaguar twist :wink: (now dead but will live on)
1996 disco 300tdi 1.2 offroad toy :D
Pocketrocket
Postby Pocketrocket » Thu Jul 23, 2015 1:25 pm
conrod wrote:My daily is a Mondeo ST220 which has basically the same engine - it's a mega engine too! I think the Jag has a different valvetrain than the Mondeo, and variable cams. All aluminium and a very compact unit. What trans are you going to run behind it? Man or auto?
Gonna be using the manual box thats already in the jag, will obv have to make up some custom engine mounts but thats not a massive problem, the only problem will be the gear stick and where to put/mount it.
Yeh we first toyed with the idea of a st24 unit just for the ease and availability of the cars but had trouble getting a diffinative answer as to what box would fit it......so then looked at jag boxes........then looked at whole jags........found they were much more powerful and here we are :lol:
Anyone need any bits from an s-type as it will be getting broken :lol:
Pocketrocket
Postby Pocketrocket » Thu Jul 23, 2015 1:27 pm
MinorMatt wrote:My diesel either gets tramp or spins, one or the other!
Im gonna aim high and say I want to be in the mid-late 15s (thats saying I can get the power down like you say)
Pocketrocket
Postby MinorMatt » Thu Jul 23, 2015 2:20 pm
Like I said in a PM... if you are going to use the transit axle I can help with that!
2 x 2006 Mk7s
Postby DodgeRover » Thu Jul 23, 2015 7:03 pm
Cool I'll be watching how you get on Tim is going to look at making me an adaptor plate to mount it to a transit box once I find a donor. The 3l makes 220 ish bhp in the car so once decated it should move a transit along nicely.
DodgeRover
Postby madbri » Thu Jul 23, 2015 9:00 pm
Pocketrocket wrote:Anyone need any bits from an s-type as it will be getting broken :lol:
engine and box please. i have a mad idear about 1 of these in a transit :!: :!: :lol: :lol:
madbri
Postby robbie.cee » Thu Jul 23, 2015 10:19 pm
Keep all switches, head lamps etc sell.em on ebay you prob get 10quid all day long for a rear window switch as an eg.... headlamps etc more !
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Fri Jul 24, 2015 9:27 am
Also i would keep the switch 0lugs and a few inch of wires too!! Fuse box all sorts of useful reusable stuff!...
If.you wanna retain computer you may need fuel sender too btw
Had
MAKE IT FIT
robbie.cee
Postby conrod » Fri Jul 24, 2015 11:21 am
Have you investigated the engine management system to see if the engine loom can be separated from the chassis loom, and if the ECU will run as a standalone system, without requiring inputs from other control modules, or speed inputs, fuel level etc?
conrod
Postby Pocketrocket » Fri Jul 24, 2015 1:27 pm
conrod wrote:Have you investigated the engine management system to see if the engine loom can be separated from the chassis loom, and if the ECU will run as a standalone system, without requiring inputs from other control modules, or speed inputs, fuel level etc?
Yeh we've got an electrical diagram manual and lukes fairly confident (electricals are his job :lol: ) that it can be run just on its own, we will probably need to keep the clocks but we'll see
Pocketrocket
