My mk5 smiley V6 Jag engined van
Re: My mk5 smiley V6 Jag engined van
Postby Pocketrocket » Fri Jul 24, 2015 1:31 pm
And there it is the engine in question :D
1991 mk3 2.5di county 4x4 lwb ex mini bus camper conversion
1999 mk5 tourneo (previously jagvan, now Vw PD powered now with new owner :cry: )
2000 mk5 with a jaguar twist :wink: (now dead but will live on)
1996 disco 300tdi 1.2 offroad toy :D
Pocketrocket
Postby robbie.cee » Fri Jul 24, 2015 2:52 pm
Not sure if i read that jag v6 mates to a mk6 mt76 ?!?!
anyone?
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby pelmetman » Fri Jul 24, 2015 3:18 pm
I hope your project goes smoother than mine :roll: ...........
They started on it in February, hopefully I'll get her back "again" before August :shock: .......
Fanny a 99 LWB Semi high roof MK 5......Essex V6 auto..... Sold
Horace a 90 SWB Ford Travelhome MK 3....2.5 diesel manual
pelmetman
Postby DodgeRover » Fri Jul 24, 2015 6:12 pm
robbie.cee wrote:Not sure if i read that jag v6 mates to a mk6 mt76 ?!?!
anyone?
Think that might have been my fault getting Duratec and Duratorque confused, from what I've found out it doesn't easily bolt up to anything other than the Getrag 221? Box it comes attached to in the jag
DodgeRover
Postby Luke » Fri Jul 24, 2015 6:57 pm
anyone?
yes that what we found too - only rwd applications we could find with non jag boxes used adapterplates :)
Pocketrocket wrote:
conrod wrote:Have you investigated the engine management system to see if the engine loom can be separated from the chassis loom, and if the ECU will run as a standalone system, without requiring inputs from other control modules, or speed inputs, fuel level etc?
Yeh we've got an electrical diagram manual and lukes fairly confident (electricals are his job :lol: ) that it can be run just on its own, we will probably need to keep the clocks but we'll see
as for the wiring it'll be a bit of trial and error we should be ok for getting it to run in the transit - someone told me he thought it would need abs sensors connecting up to run - but i'm not sure thats right, if it is i can't see too much of a problem as you can get mk5's with abs - we can try disconnecting everything in the jag before we remove the engine and if that runs ok then should be ok in the van :D
Postby robbie.cee » Fri Jul 24, 2015 9:09 pm
Abs would prob be used as speed sensor, im sure it can be tricked by using di electronic speedo sender if needs be, everyone saying cant use di one in cos v6…but Mine works and dont stall now(so Much lol)
Had
MAKE IT FIT
robbie.cee
Postby DodgeRover » Wed Jul 29, 2015 10:36 pm
Come on you've had the weekend to get at it any progress yet so I can go looking for a donor jag??
DodgeRover
Postby nick217 » Thu Jul 30, 2015 7:12 pm
how about a slab or two in the back over the axle to aid weight?
nick217
Postby DodgeRover » Thu Jul 30, 2015 8:33 pm
Twin rear wheels would help with traction too, mind the recovery my Dad built with a big block V8 would light them up with a car on suspended tow....
DodgeRover
Postby Pocketrocket » Thu Jul 30, 2015 10:02 pm
DodgeRover wrote:Come on you've had the weekend to get at it any progress yet so I can go looking for a donor jag??
Yeh not much to report at the moment, the van/jag are stored at work and all ive done is clear out the back of the van as it was 2/3rds full of rubbish!
once thats empty ill be starting on the welding thats required, it'll be a while till i tear into the jag tbh as i need the van in a state so that when the time comes its just a matter of dropping the engine/box in (he says soooo easily! :lol: )
Keep tuned as soon as start the welding ill post updates on that as well as the engine transplant :wink:
Pocketrocket
Postby Pocketrocket » Fri Jul 31, 2015 10:44 pm
Had a poke around the jag this evening and from what we can figure out is that the abs has no control over the ecu when its disconnected and that also takes off the traction control too.
Great news! :D
Engine still runs/drives etc as norm so must have a basic-ish ecu simular to that what was on my st24
Sorry not much to report but maybe an insight for you madbri/dodgerover?
Pocketrocket
Postby robbie.cee » Sat Aug 01, 2015 9:04 am
Hi mate what year was jag?
Had
MAKE IT FIT
robbie.cee
Re: My mk5 smiley jag van
Postby karl » Sat Aug 01, 2015 10:40 am
Pocketrocket wrote:On the back of my disco
evens halshaw trafford park :D
karl
Tranny Lover!!!
Postby Pocketrocket » Sun Aug 02, 2015 5:49 pm
robbie.cee wrote:Hi mate what year was jag?
Ey up robbie, the jags a "w" plate 99-00, only paid 300quid for the whole running/driving car, should be able to sell a few bits and claw a bit of cash back as everything still works! :D
Pocketrocket
Postby Pocketrocket » Sun Aug 02, 2015 5:50 pm
Yeh it is, didn't have far to take her home, just over the hill :wink:
Pocketrocket
Users browsing this forum: dumper
