Retrofitting a 2.0 Mtdi engine in a 2.2 Mk7 FWD
Re: Retrofitting a 2.0 Mtdi engine in a 2.2 Mk7 FWD
Postby mealic » Thu Aug 27, 2015 9:18 am
I can see that the campsite talk on this issue will be going on well into the "wee morn" at Mania this weekend. I really hope that everyone that has posted here will be there to defend their corner.
I somehow doubt that they ALL will. Maybe I shall be proven wrong.
`04 2.3 petrol/LPG
mealic
Postby walt1984 » Thu Aug 27, 2015 10:02 am
I have no intentions of stirring things up.
Will there be a rwd 2.4 mtdi in a mk7 conversion? . A mate of mine is looking at a mk7 with blown engine and thinking of buying and rebuilding it as he will then know its history. Ive been telling him about the conversion thats been shown on here.
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Postby bigjohnthomas » Thu Aug 27, 2015 10:13 am
I am not going, you lot will tie me up and bum me
Probably :?
bigjohnthomas
Postby Mad machinist » Thu Aug 27, 2015 11:05 am
You can always hope BJT
A subsiduary of Heath Robinson Developments
Mad machinist
Postby bigjohnthomas » Thu Aug 27, 2015 11:44 am
I am but a wrench who's bussom knows no joy :(
bigjohnthomas
Postby dieselhead123 » Thu Aug 27, 2015 1:32 pm
walt1984 wrote:I have no intentions of stirring things up.
Hi there, it would be a natural progression to offer this.
The simplest solution being to install a Mk6 2.4 Tddi engine fitted with Mk7 ancillaries and our Mdti pump. This looks to be a simpler 'swap' than the FWD Mk7 :D
Retain the Mk7 flywheel and crankshaft sensor and the rev counter will most likely work.
Postby andypdq » Thu Aug 27, 2015 8:52 pm
V184 wrote:Thanks for that :roll:
Exactly the response which you would expect from someone whose main obsession in life is to excel in the noble art of Trolling. :wink:
The first Mk 6 mechanical TDDI, giving electronics the finger, since April 2013
Perfection is reached, not when there's nothing left to add, but when there's nothing left to remove.
YouTube https://www.youtube.com/channel/UCNypVH ... dKUN5eJDyQ
andypdq
Postby andypdq » Thu Aug 27, 2015 9:17 pm
bigjohnthomas wrote:I am not going, you lot will tie me up and bum me
Probably :?
Roger that. :P
andypdq
Postby paul2012 » Thu Aug 27, 2015 10:30 pm
That's fine for the mk6 2.4 90ps that use VP30 pump. MTDI is a straight forward fitment.
2.4 engines from 115ps upwards uses VP44 pumps. You'll have to put together another pump for them.
Come to think of it. Ford already supply a mech pumps for mk6 2.4 engines 8)
For example - Mech pump for the 2.4 120/125ps TDDI engines is 1C1Q-9A543-AC :P
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby walt1984 » Thu Aug 27, 2015 10:34 pm
A 120/125 isnt the same type of pump that can fail on other mk6s?
Im still learning thats the only reason i ask.
walt1984
Postby bambi mk 1 » Thu Aug 27, 2015 10:40 pm
mealic wrote:I can see that the campsite talk on this issue will be going on well into the "wee morn" at Mania this weekend. I really hope that everyone that has posted here will be there to defend their corner.
Sorry I wont be there but will be flying over the site and if I see a Peugeot Boxer with a head in it with a mouth as big as the Grand Canyon I will pull the plug on the honey pot and dump the load on him.
bambi mk 1
Postby paul2012 » Thu Aug 27, 2015 10:53 pm
walt1984 wrote:A 120/125 isnt the same type of pump that can fail on other mk6s?
Yes Bosch VP30 & VP44 both have EDC's which do fail - Common problem
These 2 pumps are fitted to Mk6 TDDI engines.
Mk6 TDCI engines use a Delphi fuel pump with high pressure fuel rail - Known as common rail :wink:
paul2012
Postby walt1984 » Thu Aug 27, 2015 10:56 pm
Common rail been the unreliable 135ps?
walt1984
Postby bambi mk 1 » Thu Aug 27, 2015 11:11 pm
Known in these parts Walt as common fail :wink:
bambi mk 1
Postby paul2012 » Thu Aug 27, 2015 11:29 pm
Yes Transit mk6 TDCI, Transit Connect TDCI & Mondeo mk3 TDCI all use Delphi fuel systems.
They all have I thing in common - Faulty injectors :wink:
paul2012
