bleeding clutch ? transit 03 fwd 2800kg swb
Postby mickanic » Tue Apr 24, 2007 10:42 pm
Hi, I have just replaced the clutch ass and the thrust bearing ass, does anybody know if there is a special way to bleed the clutch?
many thanks Mick.
07765457424
mickanic
Postby MrMPuk » Tue Apr 24, 2007 10:43 pm
ass?
Postby motorwise » Tue Apr 24, 2007 10:44 pm
MrMPuk wrote:ass?
assembly :D
http://www.motorwise.net
motorwise
Postby mickanic » Tue Apr 24, 2007 10:44 pm
Assembly
mickanic
Postby MrMPuk » Tue Apr 24, 2007 10:45 pm
motorwise wrote:
MrMPuk wrote:ass?
assembly :D
Furry muff
Postby motorwise » Tue Apr 24, 2007 10:47 pm
I think you need to remove the clip on the pipe and pull it back to the stop (hope that makes sense) have a look when it's light :D
motorwise
Postby mickanic » Tue Apr 24, 2007 10:55 pm
I have connected the pipe and want to bleed the clutch - do you just bleed it through with a pipe and bottle? or a pressure bleeder
mickanic
Postby motorwise » Tue Apr 24, 2007 10:58 pm
mickanic wrote:I have connected the pipe and want to bleed the clutch - do you just bleed it through with a pipe and bottle? or a pressure bleeder
I personally would pressure bleed it - but there's no bleed screw is there? - I think the fluid (and air) escape when the pipes pulled back to the stop - this is from memory from a conversation I had at the clutch centre - I've not actually had to do it yet - so I hope it helps :D
motorwise
Postby mickanic » Tue Apr 24, 2007 11:02 pm
there is a bleed screw - think i will pressure bleed it - thanks for your input tonight - coco time cheers mick
mickanic
Postby motorwise » Tue Apr 24, 2007 11:03 pm
mickanic wrote:there is a bleed screw - think i will pressure bleed it - thanks for your input tonight - coco time cheers mick
I didn't think they had one - sorted then - good luck :D
motorwise
Postby transitgeoff » Tue Apr 24, 2007 11:06 pm
dont remove the clip fully pull it out a bit and the pipe can be moved back, this opens the way for air to be bled, get someone on the pedal and bleed away 8)
transitgeoff
Postby motorwise » Tue Apr 24, 2007 11:07 pm
transitgeoff wrote:dont remove the clip fully pull it out a bit and the pipe can be moved back, this opens the way for air to be bled, get someone on the pedal and bleed away 8)
I knew you'd know :D
motorwise
Postby Nighthawk » Wed Apr 25, 2007 8:23 pm
there is a twist type bleed nipple on some of the rwd clutch slave cylinders
:D
Transit.........Job done
Nighthawk
Users browsing this forum: knobby1, Trev_
