Diesel dump valve
Diesel dump valve
Postby rob hall » Sun Aug 16, 2015 4:06 pm
Has anyone on here fitted a dump valve to the tddi ?
the welsh A-team!
rob hall
Re: Diesel dump valve
Postby Punto443 » Sun Aug 16, 2015 5:10 pm
Generally it just makes them sound like a bus :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby S26coolin » Sun Aug 23, 2015 3:34 pm
Hi put a k&n filter on mine quite close to the turbo and got rid of both exhaust boxes and it sounds like it's got a dump valve on it, the turbo sounds great and van sounds real deep. No noticeable extra power tho I'm just preparing for a map
S26coolin
Postby rob hall » Mon Aug 24, 2015 9:45 pm
Hi ive done the same , but still want a dump valve
the welsh A-team!
rob hall
Postby S26coolin » Mon Aug 24, 2015 10:24 pm
Only dump valve iv known fitted to the diesels was on the old peugeot 306 dturbos. If it's the same ul need to tee into the servo for a vaccum and somehow fit a switch to you throttle (could rev the old cars under the bonnet) so this will be trickier
When you rev it the switch stops the vaccum holding the valve closed when you shut the revs off it triggers the switch opening the vaccum that opens that dump value ect it's all simple if you can tee into the servo and mod a switch to the revs. Unless people know another way?
S26coolin
Postby rob hall » Wed Aug 26, 2015 8:38 pm
There is a kit for a mondeo tdci on ebay , would it fit a 2.4 tddi?
the welsh A-team!
rob hall
Postby S26coolin » Wed Aug 26, 2015 9:45 pm
rob hall wrote:There is a kit for a mondeo tdci on ebay , would it fit a 2.4 tddi?
Is there a link fir the item so people can look?
S26coolin
Postby rob hall » Sat Aug 29, 2015 1:11 am
the welsh A-team!
rob hall
Postby rob hall » Thu Sep 03, 2015 5:19 pm
Would this fit my 2.4 tddi???
the welsh A-team!
rob hall
Postby Mike » Thu Sep 03, 2015 5:30 pm
"To eliminate compressor surge when changing gears. Excessive back pressure is created when the throttle is closed during gear changes or deceleration, causing turbo cavitation." :lol: :lol: :lol: :lol:
Mike
Wind up merchant!
Postby ake » Thu Sep 03, 2015 6:03 pm
rob hall wrote:Would this fit my 2.4 tddi???
I sure it could be made to fit, however it will achieve absolutely sod all, you'd get a better performance increase spending the money on some Ultra diesel!
Postby g-man » Thu Sep 03, 2015 6:16 pm
and some millers sport :wink:
g-man
Postby rob hall » Mon Sep 07, 2015 8:47 am
I understand that it would have no performance gains but i think it would sound cool!
the welsh A-team!
rob hall
Postby rob hall » Mon Sep 07, 2015 8:48 am
the welsh A-team!
rob hall
