Can I go to the ford shop in mingham and buy a brand spanker machanical pump for a mk6?
Or have I not being paying attention
bigjohnthomas wrote:so what's all these pumps and numbers n sh*t all about
andypdq wrote:Yes, you can, pull your pants down Roger.............
paul2012 wrote:bigjohnthomas wrote:so what's all these pumps and numbers n sh*t all about
Pump no's related to engine power & less or with immobiliser (PATs)
Yes you can go to Ford & order Ford Part No F1141377 (1C1Q-9A543-AC)
It will get you a brand spanking new mech Bosch pump for a mk6 2.4 120ps engine.![]()
Unfortunately it's more expensive than the normal VP44 pumps the 120ps use
As for the other pumps numbers. Andy/Tim may use them as reference to obtain parts/data to build their own cheaper version for the 2.4's
V184 wrote:
ps sort that BL badge out it looks like someones sat on it![]()
knobby1 wrote:andypdq wrote:Yes, you can, pull your pants down Roger.............
LOL...![]()
I think it was Frank, at 'Mania, but you weren't there.![]()
andypdq wrote:V184 wrote:So if they did a mechanical pump for the mk6 then they also did a cable throttle pedal then ?
Well, it would seem fairly obvious.![]()
V184 wrote: i was thinking you could incorporate it in your little conversion "kit" rather than the lash up you used in a previous thread![]()
Mad machinist wrote:V184 youll have to tell us what the weather is like in Australia, you must get there soon with the hole your digging, the alledged font of all knowledge cant quantify his statements and apparently hasnt heard of Delphi evo, what is it exactly youre an expert of, you seem reluctant to reveal your actual work
V184 wrote:Mad machinist wrote:V184 youll have to tell us what the weather is like in Australia, you must get there soon with the hole your digging, the alledged font of all knowledge cant quantify his statements and apparently hasnt heard of Delphi evo, what is it exactly youre an expert of, you seem reluctant to reveal your actual work
Sorry no i hadn't heard of "delphi evo" is it a crime ?
Users browsing this forum: Bing [Bot], luiscarvalho
