Retrofitting a 2.0 Mtdi engine in a 2.2 Mk7 FWD
Re: Retrofitting a 2.0 Mtdi engine in a 2.2 Mk7 FWD
Postby V184 » Thu Sep 03, 2015 9:07 pm
Mad machinist wrote:
V184 wrote:
Mad machinist wrote:V184 youll have to tell us what the weather is like in Australia, you must get there soon with the hole your digging, the alledged font of all knowledge cant quantify his statements and apparently hasnt heard of Delphi evo, what is it exactly youre an expert of, you seem reluctant to reveal your actual work
Sorry no i hadn't heard of "delphi evo" is it a crime ?
Still evading direct questions i see
Evading what ?
V184
Postby Mad machinist » Fri Sep 04, 2015 8:22 am
Evading what ?[/quote][/quote]
WHAT IS IT EXACTLY YOURE AN EXPERT OF, YOU SEEM RELUCTANT TO REVEAL YOUR ACTUAL WORK, there i wrote in big letters so you cant miss it
A subsiduary of Heath Robinson Developments
Mad machinist
Postby V184 » Fri Sep 04, 2015 9:48 am
When did i say i was an expert ?
V184
Postby MinorMatt » Fri Sep 04, 2015 9:50 am
V184 wrote:
We did try this, but since the pedal/cable assembly is intended for the Turkish market, LEFT HAND DRIVE, it made operation rather difficult in a right hand drive vehicle :wink:
Again not appearing to be dim Tim but why not use the petrol one ?
I would imagine ford want quite a lot of money for petrol pedals... and they arn't exactly in abundant supply 2nd hand! Pretty pointless having a kit designed around a part which is hard to get/very expensive...
Postby bigjohnthomas » Fri Sep 04, 2015 10:00 am
One never knows some ford stuff is good price some bad price
We need more information to support your claims my good fellow :mrgreen:
bigjohnthomas
Postby dieselhead123 » Fri Sep 04, 2015 10:02 am
Exactly MinorMatt :idea:
Utilizing the Petrol throttle pedal/cable was something we considered.
I did carry out a detailed inspection of a forum member's LPG Mk6 two years ago but the lack of availability pre-used and the cost of a new Ford part resulted in us producing our own. The Ford petrol throttle cable was unsuitable for our needs and the use of the Ford pedal required the bulkhead to be drilled in an area that would have required dash removal to accomplish, (on right hand drive vehicles at least). Consequently we felt that an alternative pedal assembly provided a simpler installation.
Our throttle pedal assembly is constructed from a number of different parts and can be assembled to suit both left and right hand drive vehicles, doing so helps to keep production costs to a minimum.
Once again Mr V184, I say that you do not appear 'dim', but your eagerness to comment on matters you clearly know little about is in keeping with the majority of your posts!
Postby bigjohnthomas » Fri Sep 04, 2015 10:04 am
How much is a new pedal then? :?
60 quid I paid for my mk6 one :x
bigjohnthomas
Postby Mad machinist » Fri Sep 04, 2015 10:06 am
V184 wrote:When did i say i was an expert ?
Ok Mr Evasive, what do you do/have you done, you enjoy the sweeping statements of lash up, heath robinson etc but fail to give valid reasoning for comments when asked, do you have any background in design, small production runs, prototypes, im sure lots on here await your reply as to how clever you are on the subjects you scathe , do astound us.
Mad machinist
Postby dieselhead123 » Fri Sep 04, 2015 10:18 am
bigjohnthomas wrote:How much is a new pedal then? :?
Why did you need a replacement throttle pedal for your diesel engined Mk6 BJT?
Did part of the 'ultra reliable' Mk6 engine management system let you down?
Or did a dog chew the pedal :shock:
Postby V184 » Fri Sep 04, 2015 10:20 am
As reliable as a cable i would have thought :wink:
V184
Postby V184 » Fri Sep 04, 2015 10:23 am
dieselhead123 wrote:Exactly MinorMatt :idea:
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: Another one for page 6 !
V184
Postby Mr RVM » Fri Sep 04, 2015 10:27 am
I've just removed a throttle cable from a transit that I have owned since it was "nearly new" in 2001, the cable has never been renewed so is at least 15 yrs old and still works fine :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Mr RVM
Postby V184 » Fri Sep 04, 2015 10:29 am
Im very happy for u pet ! :lol: :lol: :lol:
V184
Postby andypdq » Fri Sep 04, 2015 10:33 am
I suspect this is how he thinks his way around technical problems :wink: :
The first Mk 6 mechanical TDDI, giving electronics the finger, since April 2013
Perfection is reached, not when there's nothing left to add, but when there's nothing left to remove.
YouTube https://www.youtube.com/channel/UCNypVH ... dKUN5eJDyQ
andypdq
Postby V184 » Fri Sep 04, 2015 10:40 am
Greetings Andrew, sorry im off to run my empire, catch up later x
V184
