Retrofitting a 2.0 Mtdi engine in a 2.2 Mk7 FWD
Re: Retrofitting a 2.0 Mtdi engine in a 2.2 Mk7 FWD
Postby andypdq » Fri Sep 04, 2015 10:51 am
V184 wrote:Greetings Andrew, sorry im off to run my empire, catch up later x
I'm honoured sir, it's the first time I've ever communicated directly with a Deity.
The first Mk 6 mechanical TDDI, giving electronics the finger, since April 2013
Perfection is reached, not when there's nothing left to add, but when there's nothing left to remove.
YouTube https://www.youtube.com/channel/UCNypVH ... dKUN5eJDyQ
andypdq
Postby dieselhead123 » Fri Sep 04, 2015 11:14 am
V184 wrote:Greetings Andrew, sorry i'm off to push my broom, catch up later x
dieselhead123 wrote:
Once again Mr V184, I say that you do not appear 'dim'........
Sincere apologies to all those reading this thread :oops: :oops: :oops:
I appear to have made an 'error of judgment' :wink:
Postby Mad machinist » Fri Sep 04, 2015 11:34 am
Mad machinist wrote:
V184 wrote:When did i say i was an expert ?
Ok Mr Evasive, what do you do/have you done, you enjoy the sweeping statements of lash up, heath robinson etc but fail to give valid reasoning for comments when asked, do you have any background in design, small production runs, prototypes, im sure lots on here await your reply as to how clever you are on the subjects you scathe , do astound us.
Oh dear v184 you seemed to have missed my post, so here it is again, we await your definitive answers with baited breath.
A subsiduary of Heath Robinson Developments
Mad machinist
Postby andypdq » Fri Sep 04, 2015 11:47 am
V184 wrote:
Mr RVM wrote:
V184 wrote:
As reliable as a cable i would have thought :wink:
I've just removed a throttle cable from a transit that I have owned since it was "nearly new" in 2001, the cable has never been renewed so is at least 15 yrs old and still works fine :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Im very happy for u pet ! :lol: :lol: :lol:
Why are you laughing? It's older than any Mk6, how many throttle pedal or cable failures have been reported on the forum for Mk5 and older compared to throttle pedal failures of Mk 6 and younger? A new cable is much cheaper than a new Mk 6/7 throttle pedal, as the good BJT has attested to. That cable is headed in my direction, and I'm sure it will provide many more years of useful service.
Just goes to prove you are the classic example of falling for the logical fallacy of confirmation bias, I'm happy to wait a while for for your reply, while you look it up. :wink:
andypdq
Postby bigjohnthomas » Fri Sep 04, 2015 4:10 pm
159 shellkels for a gen one on noncegay :shock:
Got abouut 140k out of mine
If you type "transit t" in to egay it comes up " transit throttle pedal " :lol:
Its those bloody carbon tracks cracking up man
bigjohnthomas
Postby dieselhead123 » Fri Sep 04, 2015 5:25 pm
bigjohnthomas wrote:159 shellkels for a gen one on noncegay :shock:
I'll let you know when my 'mechanical' throttle pedal fails :wink:
Unlike you I will be unable to 'blame' Ford, I made mine myself :D
Postby bigjohnthomas » Fri Sep 04, 2015 5:45 pm
I don't blame ford Its the carbon in the tracks that was gifted to us from the supreme being
That fail so if anyone's the perpetrator its that f*** b*stard of a w*** shaft :x
Still what's 60 quid these days ?
Case of spesh?
Quick stand up with a couple of lezzers ?
bigjohnthomas
Postby pelmetman » Fri Sep 04, 2015 7:14 pm
Do they wear out? :shock: .........
I've got a 25 and a 16 year old cables in my vehicles :? .......How many arms & legs will I have to sell to replace them? :( ...........
Fanny a 99 LWB Semi high roof MK 5......Essex V6 auto..... Sold
Horace a 90 SWB Ford Travelhome MK 3....2.5 diesel manual
pelmetman
Postby Mr RVM » Fri Sep 04, 2015 7:21 pm
The only problem I've EVER had with a transit throttle cable is a broken adjuster "sleeve" at the pump end (but have fixed them by removing the broken piece then spacing the metal bracket off the front plate by adding a spacer or another nut between them) :wink:
New genuine ford cables are £30 and pattern ones are £15/£20 :wink:
Mr RVM
Postby pelmetman » Fri Sep 04, 2015 7:58 pm
Phew.........That's a relief 8) ..........
OT but I was reading a thread on a motorhome forum by a chap who had imported a new camper from Europe, but needed some RH headlights to get it registered in the UK, which he'd replace immediately with the LH drive originals as he intended to spend his time abroad..........a pair of RH headlights cost the thick end of a thousand pounds :shock: ............
I'm contemplating some MK 4 glass ones for my MK 5 which are 59 quid each, and I thought they seemed expensive :mrgreen: ..........
pelmetman
Postby V184 » Fri Sep 04, 2015 8:11 pm
Any news on the dyno results we were promised months ago Andy ?
V184
Postby bigjohnthomas » Fri Sep 04, 2015 8:24 pm
I am sure you could lash something up to use a cable throttle on a old mk6
Bolt a potentiometer on top of the pump tie a cable round it bit of a spring sorted
The allcock cable throttle coversion (ACTC) f*** buy it :P
bigjohnthomas
Postby Mad machinist » Fri Sep 04, 2015 8:38 pm
Still evading questions V184, ive asked you twice now, just go back up page a bit youll see, we wait for your answers
Mad machinist
Postby V184 » Fri Sep 04, 2015 8:41 pm
This thread is about RETROFITTING A 2.0 MTDI ENGINE IN A 2.2 MK7 FWD hopefully putting it in capitols it might sink in :roll:
V184
Postby Mad machinist » Fri Sep 04, 2015 9:06 pm
V184 wrote:This thread is about RETROFITTING A 2.0 MTDI ENGINE IN A 2.2 MK7 FWD hopefully putting it in capitols it might sink in :roll:
AND I HAVE BEEN ASKING YOU TO QUANTIFY YOUR STATEMENTS, TELL US ALL YOUR QUALIFICATIONS TO MAKE SUCH SWEEPING STATEMENTS, ALSO DONE IN CAPITALS (SPELT CORRECTLY) SO IT MIGHT SINK IN TO YOU, PUT UP OR SHUT UP
Mad machinist
