VAG 1.9 TDi into a RWD transit
Re: VAG 1.9 TDi into a RWD transit
Postby madbri » Wed Aug 26, 2015 9:09 pm
is it going to mania?
madbri
Postby Luke » Wed Aug 26, 2015 10:32 pm
madbri wrote:is it going to mania?
almost certainly :!: ....................................... be at Transitmania 8 :lol:
Postby Luke » Wed Sep 16, 2015 7:29 pm
well i didn't make Transitmania 7 or the Revolution van meet at Skeggy :( so i left it for a bit - sometimes a break is a good thing :lol:
decided to buy a new round header tank and made this bracket for it
need to do a bit more work on the pipes - repair a stripped thread in the block and fill it with water....................... :D
still not sorted an ideal intercooler :?
Postby dieselhead123 » Wed Sep 16, 2015 7:48 pm
Given how much room you have above the engine, why not fit a chargecooler?
It's not like you'll need access to the engine for maintenance, it's a VW :wink:
The chargecooler rad will be slimmer than an air/air intercooler so might also solve some of the space issues up front and you get to make another 8) looking tank bracket.
Tidy 'fab' work as normal though 8)
Postby Luke » Wed Sep 16, 2015 7:54 pm
cheers Tim :D i'd thought about a charge cooler same as i've got on the 2JZ but its all the other stuff that goes with it and this isn't a 'performance' engine - if you know what i mean :)
i might end up with an intercooler in that space :?
Postby bulls in transit » Fri Sep 18, 2015 5:39 pm
Used to have a nissan navana,intercooler sits on top of engine,intake through scoop on bonnet,but looking at your picks wouldnt one fit on top of your engine,clear bonnet,an custom top with a 3",4"pipe leading to intake down near front cross member,?also plenty in breaker with blown ends....intake wouldnt have to be big,very visable,just similar cross section area to bonnet scoop
bulls in transit
Postby martynx » Fri Sep 18, 2015 6:02 pm
You could try no intercooler !
martynx
Postby Luke » Fri Sep 18, 2015 9:55 pm
bulls in transit wrote:Used to have a nissan navana,intercooler sits on top of engine,intake through scoop on bonnet,but looking at your picks wouldnt one fit on top of your engine,clear bonnet,an custom top with a 3",4"pipe leading to intake down near front cross member,?also plenty in breaker with blown ends....intake wouldnt have to be big,very visable,just similar cross section area to bonnet scoop
i'm trying to keep it looking factory from the outside - so i'm not really wanting a bonnet scoop...................... but you never know :lol:
martynx wrote:You could try no intercooler !
what sort of power loss do you think i'd suffer? i might just pipe it up like that while i'm looking for a suitable one :idea:
Postby bulls in transit » Sat Sep 19, 2015 1:14 pm
With navrana intercooler i meant top inside bonnet,intake pipe down side of engine,intake"scoop"at crossmember level,not affecting bonnet line
bulls in transit
Postby Luke » Sat Sep 19, 2015 3:00 pm
bulls in transit wrote:With navrana intercooler i meant top inside bonnet,intake pipe down side of engine,intake"scoop"at crossmember level,not affecting bonnet line
i see :idea: - i'll take a look at a navarna intercooler then :D
Postby martynx » Sat Sep 19, 2015 3:02 pm
Not too sure Luke.. in colder weather probably not much.. you'll get better throttle response without one though as a bonus. .. & I can probably adjust the fueling to compensate for a small loss anyway.. give it a whirl !
martynx
Postby cocksocks » Sat Sep 26, 2015 10:43 am
awsome thread
cocksocks
Postby MinorMatt » Wed Sep 30, 2015 5:37 pm
So are you going to get a recall letter from VW? :lol:
Postby axxez » Fri Oct 23, 2015 2:42 pm
Lol, nice one! :D
Will loose warranty if the emission-problem will not be fixed ;-)
axxez
