Mk7 denso injectors
Re: Mk7 denso injectors
Postby martynx » Wed Sep 30, 2015 1:18 pm
095000-7060              6EHU095000-7060  60409943390 https://www.ebay.co.uk/itm/313050970413
martynx
Postby loot » Mon Oct 05, 2015 8:50 pm
New rocker cradle, new rocker cover.
1 28 pounds injector.
Replaced 3 nozzles 885, and pins, were second hand from Duff injectors, suspect the balls were fitted flat side up :roll:
But they all looked newer than mine, torqued up.
New clamps and bolts, torqued up + 180 degrees, no leaks visible.
Sweet, just a leak off test tomorrow and we're done.
No idea if the spray pattern is clean or whether any are over fueling tho :?
07 350 170ps
Ids map here
loot
Postby loot » Tue Oct 06, 2015 4:55 pm
Leak off test results are in.
Old.
4 mins@tickover
1@32ml
2@34ml
3@36ml
4@51ml
New nozzles and pins on 1/2/3
28 pounds injector off eBay (always questionable but worth a go at that price)
Results
1@30ml
2@30ml
3@26ml
4@25ml
Tolerance is 25ml to 40ml
Looks like a result to me 8)
I don't have the facility to visually inspect spray pattern or measure fuel flow, ids passed injector learn on the second attempt, suspect i should have given it a good run to clear all the air out and lubricate the pins thoroughly.
Nonetheless they passed ids learn so for now I'm very happy.
Also when they failed the first learn it was almost immediately on test point 4 and i could hear odd sounds, probably for the above reason but the interesting thing is that ids reported something along the lines of, test aborted, validity of performing this procedure is being looked into. :lol: yes and the result was..... Fook denso off and use Siemens :roll:
Ooosh :o
07 350 170ps
Ids map here
loot
Postby knobby1 » Tue Oct 06, 2015 10:19 pm
Nice simple & usable setup there Loot...I have a similar setup but with "baby bottles" instead of the "manky" ones you have... I get similar results to you @ idle...within a few mill's either way...:wink: :mrgreen:
I see you just did the test at idle like we thought it should be done, I guess that's the right method going by our results, well done Sir.
Postby loot » Tue Oct 06, 2015 11:25 pm
:lol:
I have baby bottles too, those manky bottles thank you were brand new but they went like that after my first leak off test :?
07 350 170ps
Ids map here
loot
Postby bambi mk 1 » Tue Oct 06, 2015 11:45 pm
loot wrote::lol:
Could you not have went to the loo or are you like a Willi Betz driver :?:
bambi mk 1
Postby knobby1 » Wed Oct 07, 2015 1:59 am
loot wrote::lol:
Mine stayed relatively clear after having diesel in 'em.....I still say yours are manky...! :wink: :mrgreen:
Postby shedrool83 » Sun Oct 11, 2015 3:58 am
Loot what what i.d of hose did you use for you leak off test kit?
shedrool83
Postby loot » Sun Oct 11, 2015 9:01 am
Amnesia :-(
I bought a roll of window washer pipe to add my rear window wipers ages ago and i used that for my leak off pipes :-)
You need to measure the o.d of your injector leak holes the pipe slots inside them, gently unclip the leak pipe off the top and put a tape across :-)
07 350 170ps
Ids map here
loot
Postby shedrool83 » Sun Oct 11, 2015 9:25 am
No bother .So your hose fits inside the leak off hole of the injector.
I was going to get hose that went over it.
I should of checked the size last week when i did the injectors washer but remembered once everything was back together :lol:
shedrool83
Postby karl » Wed Oct 28, 2015 2:00 pm
bored today so found this video 8)
how to strip and rebuild a denso injector
https://www.youtube.com/watch?v=6XJb0ghya0w
karl
Tranny Lover!!!
Postby loot » Wed Oct 28, 2015 2:17 pm
karl mcghee wrote:bored today so found this video 8)
You weren't bored enough tho Lol
viewtopic.php?f=5&t=162185
07 350 170ps
Ids map here
loot
Postby karl » Wed Oct 28, 2015 2:34 pm
:lol: :lol: :lol: :lol: o well thought id post the first post video then :lol: :lol: :lol: :lol:
karl
Tranny Lover!!!
Postby loot » Wed Oct 28, 2015 5:03 pm
:lol: it's the thought that counts 8)
07 350 170ps
Ids map here
loot
Postby loot » Sat Feb 13, 2016 2:25 pm
Right, my van runs as it should, however, recently if i leave it on tickover for a while it starts hunting.
I was playing with ids and in pcm i selected the 4 injectors.
1. 4.xxx
2. -1.5
3. 3.5xx
4. 3.5xx
Changes when i Rev.
Egr gives no faults but may be questionable although egrdc was looking good.
Not sure if the cylinders are measured on average or singular so i can't tell if it is the hunting causing it? Although it wasn't apparently doing it when seeing the number.
Don't have cfr or vmm so can't do a injector flow test :-(
Leak off test shows good.
Possible prv/scv that needs checking although the scv voltage looked within spec. :?
I'm fairly sure a pump and injectors learn will cure it but that leads me to think....... WTF does it need doing every few months (on my van)?
Bloody Ford.
Any ideas?
Going to rotate the batteries, check prv/scv, learns.
Then it'll be sending injectors away? Not sure i fancy that tbh :cry:
If i jump in the van and go it drives great, no smoke, very smooth, plenty of power.
Am i being influenced by ocd? Hmmm.
07 350 170ps
Ids map here
loot
