DiscoDan wrote:Sorry to bring up an old thread but I've pretty much got the same problem, same van, just randomly cut out on the motorway whilst I was away in France, got it brought back home and I just get the P1631 code, if I clear it then try to start it again, the code reappears.
I've posted a quick video of what it does when I try to start it: http://vid193.photobucket.com/albums/z20/discodaniel11/Mobile%20Uploads/IMG_7016.mp4
So far I have had a quick nosey over some of the wiring.
Swapped a few relays around to test.
Cleaned up my battery connections.
Also put on a spare starter I had - Checked the voltage to the starter an that's fine.
Does anyone have any advice? Thanks in advance
paul2012 wrote:Too possibilities...
1. Battery Useless - May have volts but not enough cranking amps.![]()
2. Lazy starter motor.
I would replace battery first.
