AlanN's MK3 V6 Day Van
Re: AlanN's MK3 V6 Day Van
Postby dirtydog » Wed Oct 07, 2015 9:42 pm
They are pretty nifty, I've used them a couple of times on access panels covering pipe work that sort of thing
dirtydog
Postby AlanN » Wed Oct 07, 2015 10:54 pm
Couldn't find anyone who sold those button clips around here and I'm too impatient to order them, so I brought keku clips instead after seeing them on that site from screwfix.
Roll of Grey vinyl arrived today, so I just had to have a play...ImageImageImage
A bigger contrast between the two vinyls, but I'm sure I will get used to it
Postby dirtydog » Wed Oct 07, 2015 11:57 pm
I did think of the Keku clips but wasn't sure if they'd have enough grip for fitting stuff horizontally
dirtydog
Postby AlanN » Thu Oct 08, 2015 10:15 pm
No me nether, but I'll try anything once, the keyhole version of the button clip isn't going to work, not enough room to lift the panel up and over button, but maybe a blob of silicone with help the stay in place.
Postby AlanN » Mon Oct 19, 2015 8:26 pm
All the battens bonded to the roof and some foil insulation glued up, rubbed loads of old glue off the sides. Image
The keku clips gripped brilliantly and have been holding out for a few days even with driving
Until I noticed that the plywood was starting to bend under the clips tonight! I released one of the clips and it straightened out, so I took them all off and replaced them with some timber strips screwed top and bottom to spread the weight out. Old ways are the best ways. Just gonna make it so much harder to service
Postby AlanN » Mon Oct 19, 2015 8:38 pm
Oh tested downlighters and LEDs too! Less blue when all covers go on
Postby jolly olly » Mon Oct 19, 2015 8:51 pm
Looking really good there Alan, those Keku clips are really handy bit of kit.
Life is not a dress rehearsal
jolly olly
Postby mr Grimly » Tue Oct 20, 2015 7:36 pm
Very nice mate, 8)
mr Grimly
Postby robbie.cee » Thu Oct 22, 2015 2:09 pm
Looking awesome All... Bit electric blue, like a proper passion wagon now!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby rob-xcar » Thu Oct 22, 2015 7:48 pm
Brilliant bit of work .
rob-xcar
Postby AlanN » Fri Oct 23, 2015 8:13 pm
All your fault Robbie :lol:
Postby robbie.cee » Mon Oct 26, 2015 8:55 am
AlanN wrote:All your fault Robbie :lol:
How much to do me some panels for my rear most side ' not windows'.... I can do the lights its the cutting friggin wood straight I can't do!
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Mon Oct 26, 2015 8:08 pm
No problem Rob, your gonna need some 5mm plywood sheet in a hurry as I'm going be bonding the template to van this weekend
It took quite a while to get the shape right, can you get over Saturday for a couple of hours, I can cut them out for you.
Postby AlanN » Mon Oct 26, 2015 8:21 pm
Bit more done over the weekend progress is a little slow due to all the fettling and problems with the the new drivers but I've ordered a 12A remote driver unit, which should arrive this week
Started to glue on some vinyl yesterday too, started around the corner posts, looks ok after some experimenting with folding the seems and an iron
Postby mr Grimly » Mon Oct 26, 2015 8:58 pm
Very nice, getting very posh :wink:
mr Grimly
Users browsing this forum: pamcho
