This is just a update in my fault with the Hid
The photo shows the message I was getting and one light would fail to light. I removed the lights with all the wiring and cleaned every connection then with a small screwdriver closed up all the connectors so they are all a tight fit . I even cleaned the ford connections on the light unit and put it all back together. I have been using the van for a week turning the lights on and off as much as possible with out any faults.
I cannot say which connector was playing up as I did all of them but if they start to give faults again I will just do one connector at a time .
I found that the first time I fitted them and again when they gave me replacement ballast they worked without fault for about a four to six weeks.
They are now working with auto lights or using the switch with engine on or off so fingers crossed for the winter.
