loots mk7
Re: loots mk7
Postby Tango330 » Sun Aug 30, 2015 10:34 pm
loot wrote:No, you should be able to read the van config but you need a had decent laptop or it can freeze with programming functions :-(
2gb ram is OK tho :-)
Hmmm, that might be the problem then, had to put it on the old lappy (wouldn't have it on the W8 one)and I don't think it has 2gb, I'll have to see if I can upgrade it :?
T330 RWD now sold
Ford Ranger Wildtrack now sold
MI 5 sacked me from my job as an interrogator this morning, didn't like to ask why :?
Tango330
Re: loots mk7
Postby loot » Sun Aug 30, 2015 10:37 pm
W8 64bit i don't think it works on w8 32bit, another member said it worked on his w10 upgrade but it didn't work on my mini tablet w10 but said the same thing 'insufficient hardware :-('
07 350 170ps
Ids map here
loot
Re: loots mk7
Postby Tango330 » Mon Aug 31, 2015 9:09 am
No worries Mate, I've ordered some ram for old lappy now, so that should sort it :)
T330 RWD now sold
Tango330
Re: loots mk7
Postby Tango330 » Wed Sep 23, 2015 5:03 pm
OK Loot mate, hope you enjoyed your hols in Cumbria. Worked up there for a year at Sellafield (called Winscale then), probably glow in the dark now :lol:
I finally got my RAM from the foreign blokey on egay and installed it, and hey presto retrieve vehicle config worked a treat :D
Went in the modify, and changed to heated rear windscreen, plus changed to upshift warning while I was there to see if that worked :) But, the rearwash wipe is set to no rear wash wipe, and there's no option to change it :(
Upside is that heated rear works, and I get power to the connectors for the screen so no re-wiring required :D
Any ideas on the wash wipe :?: Obviously, my washer works as I have the double pump and c-max stalk, but no wipe :(
T330 RWD now sold
Tango330
Re: loots mk7
Postby loot » Wed Sep 23, 2015 6:05 pm
Pm sent. :-)
07 350 170ps
Ids map here
loot
Re: loots mk7
Postby loot » Sun Oct 04, 2015 8:12 pm
Started doing the injectors.
Old number 4 is looking a but fooked :lol:
I struggled to get the extra washer out.
Cleaned everywhere up and need to replace the rocker cover tomorrow, got some pictures of the faces on my endoscope which I'll post if i don't forget :o
07 350 170ps
Ids map here
loot
Re: loots mk7
Postby Tango330 » Sun Oct 04, 2015 10:49 pm
Nice one Loot, mucky stuff this diesel eh :roll:
T330 RWD now sold
Tango330
Re: loots mk7
Postby loot » Mon Oct 05, 2015 12:09 am
Certainly is Lol :-)
07 350 170ps
Ids map here
loot
Re: loots mk7
Postby MinorMatt » Mon Oct 05, 2015 9:04 am
Tango330 wrote:OK Loot mate, hope you enjoyed your hols in Cumbria. Worked up there for a year at Sellafield (called Winscale then), probably glow in the dark now :lol:
My condolences... I have been there once to get the paperwork sorted for working at the place just down the road...
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Re: loots mk7
Postby Tango330 » Mon Oct 05, 2015 9:12 am
Thanks, yes, they are very keen on getting that paperwork sorted too eh :? A contractor that worked there when I was there tried to fiddle it, and got arrested in the middle of the night :shock:
T330 RWD now sold
Tango330
Re: loots mk7
Postby loot » Tue Oct 06, 2015 4:56 pm
Leak off test results are in.
Old.
4 mins@tickover
1@32ml
2@34ml
3@36ml
4@51ml
New nozzles and pins on 1/2/3
28 pounds injector off eBay (always questionable but worth a go at that price)
Results
1@30ml
2@30ml
3@26ml
4@25ml
Tolerance is 25ml to 40ml
Looks like a result to me 8)
I don't have the facility to visually inspect spray pattern or measure fuel flow, ids passed injector learn on the second attempt, suspect i should have given it a good run to clear all the air out and lubricate the pins thoroughly.
Nonetheless they passed ids learn so for now I'm very happy.
Also when they failed the first learn it was almost immediately on test point 4 and i could hear odd sounds, probably for the above reason but the interesting thing is that ids reported something along the lines of, test aborted, validity of performing this procedure is being looked into. :lol: yes and the result was..... Fook denso off and use Siemens :roll:
Ooosh :o
07 350 170ps
Ids map here
loot
Re: loots mk7
Postby Brains_transit » Sun Feb 21, 2016 7:21 pm
Good work there son
Brains_transit
Re: loots mk7
Postby loot » Sun Feb 21, 2016 7:58 pm
Thanks dad :P
07 350 170ps
Ids map here
loot
Re: loots mk7
Postby loot » Mon Mar 07, 2016 7:07 pm
Been on a day and I've cleared them so we'll see, ironically it appears every time I'm at low revs not under load :-)
07 350 170ps
Ids map here
loot
Re: loots mk7
Postby paul2012 » Mon Mar 07, 2016 8:49 pm
No IDS :?:
Or have you given up & gone generic :roll: :lol:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
