Smartalec wrote:The speed limiter is not in the ECU its in the BCM (Body control Module) and this needs IDS to remove it.
Really ?? The "upper " 100mph limiter ?? I remove it without IDS & without touching the BCM!
martynx wrote:Smartalec wrote:The speed limiter is not in the ECU its in the BCM (Body control Module) and this needs IDS to remove it.
Liliflower wrote:Problem solved:
https://www.facebook.com/lindaobd/posts ... 2597227739
moley551 wrote:Just an idea....has anyone removed the speed signal, some bikes had limiters fitted that could be defeated by removing the speed signal or emulating a lower one. It could be as simple as cutting the right wire.....a bit like bomb disposal!!!!!
