EX RAC VAN OWNERS
Re: EX RAC VAN OWNERS
Postby wronghole » Fri Mar 04, 2016 12:00 pm
Thanks :D Was going to put sport stripes down it. But thought no, maybe a bit OTT :mrgreen:
wronghole
Postby martynx » Fri Mar 04, 2016 5:58 pm
Looks sick :mrgreen: , well played.. 8) i want a built in 2nd temp gauge now :D
martynx
Postby wronghole » Fri Mar 04, 2016 6:42 pm
martynx wrote:Looks sick :mrgreen: , well played.. 8) i want a built in 2nd temp gauge now :D
Now thats something l can do for you amigo as it don't involve all that black magic stuff :D .
wronghole
Postby wronghole » Fri Mar 04, 2016 6:50 pm
anyway its a voltage meter . But l can still do it for you. :mrgreen:
wronghole
Postby martynx » Fri Mar 04, 2016 6:58 pm
14.3..must have been thinking it's summer already !;)
martynx
Postby wronghole » Fri Mar 04, 2016 7:06 pm
martynx wrote:14.3..must have been thinking it's summer already !;)
Comes with old age mate, trust me l know . :roll:
wronghole
Postby wronghole » Fri Mar 04, 2016 8:46 pm
Looks like we've been moved into a corner :( :?
wronghole
Postby ake » Sat Mar 05, 2016 10:11 am
wronghole wrote:Looks like we've been moved into a corner :( :?
Not a corner, but the correct section ;)
Postby wronghole » Sat Mar 05, 2016 2:25 pm
Fitted new gear knob :D
wronghole
Postby wronghole » Tue Mar 08, 2016 10:14 pm
Must be more oranges out there :D :D
wronghole
Postby Brains_transit » Thu Mar 10, 2016 1:35 am
When I first seen your dashboard I thought you had sanded it down to paint then I zoomed im and realised it was the finish :lol:
Brains_transit
Postby wronghole » Thu Mar 10, 2016 7:47 am
Brains_transit wrote:When I first seen your dashboard I thought you had sanded it down to paint then I zoomed im and realised it was the finish :lol:
Yeah bit of a rush job l know. Eyes are not what they used to be, thank god l haven't got "zoom" installed on the van :lol:
wronghole
Postby mk2xr2 » Thu Mar 10, 2016 10:13 pm
Hi All.
My 2008 Ex RAC van is feeling like it's due a new clutch ( currently @ 160,000 miles). In the Lex Autolease paperwork it had the clutch and flywheel replaced at 67601 miles. I've been searching the forum trying to find out which flywheel these RAC vans were fitted with from the factory, without much luck. I popped into my local Ford dealer today, to hopefully get the answer there. He looked it up on his parts system and told me it would be a dual mass flywheel setup. Is this correct or were they fitted with the SMF as they were a special build order for the RAC.
He did say they do a conversion kit for the van to run the SMF and gave me all the relevant finis numbers.
So has anyone got the definite answer?
Rob.
mk2xr2
Postby wronghole » Thu Mar 10, 2016 11:15 pm
mk2xr2 wrote:Hi All.
Rob.
Hi mate, the vans would have been fitted with dmf. I have changed mine to smf and had no problems to date.
Lots of members on here have different opinions, but mine is sorted and prefer it to the original.
There has been a lot written on here about the pros and cons of smf conversations. Hope this helps. :mrgreen:
wronghole
Postby mk2xr2 » Thu Mar 10, 2016 11:37 pm
Hi.
Thanks 'Wronghole' for the reply. I will do a bit more research on here into the DMF and SMF debate. I have found the current setup in my van fine, apart from the worn issues I am currently experiencing. If I was to stick with the factory setup, am I right in thinking the flywheel should also be renewed along with the clutch kit and bearing assembly? Chap in the Ford dealers said it all should be replaced at the same time.
Bit pricey for the parts from Fords :shock:
mk2xr2
Return to Transit Talk
cron
