spud_mab is back with another van, this time a Mk6 tourneo
Postby spudmab » Mon Mar 14, 2016 6:15 pm
As the title says I'm back with another van, this time a Mk6 tourneo, I have has a few other vans over the years but not done anything with them apart from drive them, lol.
Anyway I pick up my new tourneo a few weeks back for the pricey sum of £450.00 it's a 54 plate in not to bad condition. The reason it was cheap, well where do I start,
The biggest problem it had was every time you let of the throttle the van died, turn the key and it would start up again. It's apparently had a mondeo engine swop and it's never been right. Well I managed to get it home and I plugged my code reader in and it said ATC, so i started to have a look about and I found out that there was a few loose plugs, looked underneath and the ATC sensor wasn't connected, plugged it in and the van runs with out the cutting out.
Next on the list is get it to perform like I think it should, so yesterday I decided to pull the turbo, egr system and inlet manifold to give it all a clean up, the vanes on the turbo where nearly ceased solid and the egr system is nearly blocked with gunk. Might explain the lack of power.
Anyway I will get some photos up later
spudmab
Re: spud_mab is back with another van, this time a Mk6 tourn
Postby spudmab » Mon Mar 14, 2016 6:53 pm
[imgImage
As you can see the engine is a bit of a mess, plus most of the aircon parts have been removed, witch I need to find, it has rear aircon as well so I think it's harder
spudmab
Re: spudmab is back with another van, this time a Mk6 tourne
Postby spudmab » Tue Mar 15, 2016 1:52 pm
Well I have been out working on my new tourneo and I have been trying to sort out the many loose and broken bolts.
spudmab
Postby Brains_transit » Tue Mar 15, 2016 2:06 pm
Paul2012 just fitted a mondeo engine in his mk6 so he might be able to iron out any spare plugs
Brains_transit
Postby paul2012 » Wed Mar 16, 2016 6:29 am
Brains_transit wrote:Paul2012 just fitted a mondeo engine in his mk6 so he might be able to iron out any spare plugs
shouldn't be any spare plugs when using mk6 TDCI engine subloom :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby spudmab » Wed Mar 16, 2016 4:57 pm
The only part of the loom I'm confused with is the sub loom that plugs in down behind the drivers side headlight, it plugs into the air-con pump, not sure where the other plugs go, can't seem to find any connections around this area
spudmab
Postby spudmab » Wed Mar 16, 2016 6:16 pm
This is the sub loom I'm on about
This is the plug where it connects to the van
The plug on the left goes to the air-con pump, anyone know what the other plug is for
spudmab
Postby paul2012 » Thu Mar 17, 2016 5:51 am
spudmab wrote:The only part of the loom I'm confused with is the sub loom that plugs in down behind the drivers side headlight, it plugs into the air-con pump, not sure where the other plugs go, can't seem to find any connections around this area
Posted info here :arrow: viewtopic.php?f=5&t=168460#p1430641 :wink:
Just noticed your location. Littleport - You're just down the road from me 8)
paul2012
Postby spudmab » Thu Mar 17, 2016 9:14 am
Thanks paul2012 I have just seen, I did notice that you are close to me when I read your build, was thinking it would be handy to get to know you as you seem well clued up on these later vans, I'm more old school Fords and motorbikes,
spudmab
Postby spudmab » Fri Mar 18, 2016 7:27 pm
Well today is a good day, finally got everything rebuilt and freshened up, stripped down the turbo and completely rebuilt it, cleaned the inlet manifold and fitted new rubber gaskets, cleaned the egr system, repaired the drivers side engine mount, replaced the airbox as it was broken, fitted clamps on all the pipes as most where missing, filled up the power steering fluid and repaired the mounting bracket, repaired the headlight wiring, fitted new electric wing mirrors, repaired the abs wiring loom, fitted the drain of pipe work.
Some other bits but can't remember, the van started first turn and it seems to rev really nice now, both mirrors work spot on, head lights now work, engine bay is looking like it should.
All in all I'm very happy with today's progess.
spudmab
Postby Brains_transit » Fri Mar 18, 2016 8:07 pm
Nice one 8)
Brains_transit
Postby spudmab » Sat Mar 19, 2016 12:06 pm
Just out in from a test drive, all I can say is wow, the van seems to be flying, seems loads faster than my 2.4 mk6. Well worth the cut nuckles and dirty fingers.
Just have a few minor issues to work out,
Battery light is staying on all the time, have checked the relays and fuses and it is charging,
A whining noise from the power steering.
But all in all I'm a happy chappy
spudmab
Postby spudmab » Sat Mar 19, 2016 4:26 pm
Just been our and done some work on the inside of the van, replaced the passenger air vent as it was broken, fitted the secondary power socket at the bottom of the dash, wiring was there, socket was missing.
Things are really taking shape now, hopefully be on the road Thursday 24th as insurance should start then. Couldn't get my insurance swapped from my other van as the tourneo comes up as a car, lol, can't work that out but insurance company have transferred my 8 years commercial no claims bonus to the tourneo car insurance.
Still not sure what's causing the battery light but I'm thinking of buying a new voltage regulator and trying that.
Also any one have any suggestions on sorting out a floppy gear leaver, I have check the 10mm bolt at the gear box end and that is tight.
spudmab
Postby paul2012 » Sat Mar 19, 2016 8:19 pm
spudmab wrote:Just been our and done some work on the inside of the van, replaced the passenger air vent as it was broken, fitted the secondary power socket at the bottom of the dash, wiring was there, socket was missing.
Transit van is vehicle cat N1 (Light goods vehicle)
Tourneo is vehicle cat M1 (passenger vehicle) same as normal cars & MPV's. Plus you can drive at the normal speed limits set for cars. :wink:
& road tax price is different compared to vans
paul2012
Postby Finn_Timo » Sat Mar 19, 2016 9:06 pm
This is same here in Finland, even those categories are same! EU has some influence, maybe?
Ford Tourneo SWB '07 with 130HP, 9 seater bus made by PROFILE
Tonic
Also there are 1- 3 other MK6's, stock changes...
Finn_Timo
