Recalls issued for Transit mk8's
R/2015/025 ENGINE MAY CUT OUT - Build Date from 12/09/2014 to 26/01/2015
A batch of fuel injectors may have been assembled incorrectly. The internal valve can fail and cause reduced fuel pressure and engine shutdown with no restart.
- Recall the vehicles that are likely to be affected and check the injectors. If the injectors of concern are fitted they will be replaced.
